Brake fluid flush extra with B service
My question is: What will my B service cover? If all I have are regular maintenance items, should I pay extra? Is the brake fluid flush extra? Is it necessary?
Your Pre-paid Service will include Brake Fluid Flush..
Which in turn offers a greater prepaid service "savings" when purchasing a 3-pack/3yrs-30K when approaching 20K (or 40K) IF you plan to own your MB for 3yrs/30K more - which gets you B+A+B - frankly that's killer savings.
Please understand the 20K/2Yr brake fluid flush recommendation originated with the brake fluid manufacturer's spec/recommendation.
If you need to "stress less" - and I don't feel insecure about you felling concerned - I would recommend you do (2) things which are quite straightforward : (1) download your maintenance schedule for your Mb from mbusa.com under the Owner's Section (2) with that schedule - and your VIN# - call MB Customer Care (800) 367-6372 and review with them BEFORE you go to your dealer.
For those with pre-owned Mercedes with mileage - or those planning to own/drive their new Mercedes out past 40K-50K - you also should consider having Pre-Paid maintenance to cover Transmission Service and Spark-Plug change at the mileage/interval those are called for - which again ARE covered by Prepaid Maintenance - to maximize your savings on those services as well.
Please understand you CAN'T buy Pre-Paid maintenance after a Service Check-In - you can buy it immediately BEFORE Check-In if you know it gives you savings..
Please remember - with low mileage like your's - to use up the service's based on the recommended 1yr - at most 14 months - or you "lose"/expire that Service.
Keep the beat !
Pre-paid service is suppose to cover everything your maintenance manual states for the car for the next particular service and mileage.
SO say you have coming up 60,000 mile B service - Read maintenance manual for 60k and this is what should be covered by pre-paid service.
If it says brake fluid change then they do it as part of what you paid already.
IF it says SPark plug change they change plugs and you paid already.
you can buy these pre-paid plans from any dealer - shop around...
B Service is Oil, filter, brake fluid change with inspection (plus wiper blade??)
It really doesn't add up to the price the dealers are charging.
Most reputable indy shops in my area charges about the same as dealers as well.
Only 10 years ago, MB dealer used to charge $200 for A and $400 for B. Now, it's double which translates to 7% increase annually.
This is directly from a Dealer's website on B service.
- Synthetic Motor Oil Replacement
- Oil Filter Replacement
- Cabin Dust/Combination Filter Replacement
- Brake Fluid Exchange
- All Fluid Level Checks & Corrections Are Dependent On Factory-Recommended Service Intervals For Your Vehicle's Year & Model.
- Tire Inflation Check & Correction
- Brake Component Inspection
- Reset Maintenance Counter
