W205 C300 - stay away. Piston cracked at 65 K miles.
The additional 2 digits at the end (80) mean it's a remanufactured part therefore the following must be outdated
b2bconnect.mercedes-benz.com/gb/products/remanufactured-parts/cars/engines/basic-engine
https://wossnerpistons.com/products/9530
If anyone is interested below are MB part numbers for OEM pistons for the M274 and M264
M274920 Piston Part No : 274920 2740300900
Bore 83.0 mm
Stroke is 92.0 mm
Compression ratio 9.8:1
https://www.motorreviewer.com/engine.php?engine_id=176M264920 Piston Part No : Variant One - 2640302100 AND Variant Two 2640302200 (yep two versions)
Bore 83.0mm
Stroke is 92.0 mm
Compression ratio 10.5:1
https://www.motorreviewer.com/engine.php?engine_id=177
After Mercedes needing an extension to respond, they finally responded and know that they can’t get into a deeper hole. They now asked if I want them to repair my vehicle and pay for the inconvenience or to reimburse me for my car for the price I originally bought it for. Given this awful new vehicle market, I chose to repair my vehicle so my lawyer is getting back in touch with them and we’ll wait to find out the final decision. As of now the repair has not been approved YET.
I also have another 2017 E300 4matic but white instead of black. It has 102,000 miles and is way more neglected than the black one (haven't changed the oil as frequently, had a check engine light on for the PCV breather hose and thermostat on for about 1.5 years, changed the spark plugs for the first time at 82,000 miles instead of the recommended 30,000 miles, etc).
i don't believe it's every engine with this issue. You should be fine
California car, W205 C300 4 matic. Slightly over 4 years, about 65K miles.
Timely serviced etc.
Cracked piston in cyl 1.
Mercedes refuses to cover 100% of repair costs , which is in my view ridiculous as cracked piston is not something that normally happens as the result of normal wear and tear, especially in a 4 year old car.
This will be my last Mercedes, lesson learned ! Bye, Mercedes.
