W205 C300 - stay away. Piston cracked at 65 K miles.
Old Jan 1, 2019 | 02:55 PM
dimbmw's Avatar
w-205
Maybe someone will find it useful.
California car, W205 C300 4 matic. Slightly over 4 years, about 65K miles.
Timely serviced etc.
Cracked piston in cyl 1.
Mercedes refuses to cover 100% of repair costs , which is in my view ridiculous as cracked piston is not something that normally happens as the result of normal wear and tear, especially in a 4 year old car.
This will be my last Mercedes, lesson learned ! Bye, Mercedes.
Old Jan 1, 2019 | 03:23 PM
Elbandito's Avatar
2015 c300
Do you have an extended warranty?
Old Jan 1, 2019 | 03:25 PM
dimbmw's Avatar
w-205
nope.
Old Jan 1, 2019 | 04:17 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Did you have wrist pin problem/repair?
Old Jan 1, 2019 | 05:00 PM
dimbmw's Avatar
w-205
no, I didn't, could that cause it? were there any recalls? thanks!
i watched the youtube video about it
and i think i did have about the same noise
Old Jan 1, 2019 | 05:38 PM
Elbandito's Avatar
2015 c300
No recall, but a lot of the cars had this issue. The problem is you’re out of warranty coverage so the dealers / mbusa will probably have no obligation to repair the issue. I made sure to purchase an extended warranty cause these 2015 w205s are POSs. The reason they repaired the wrist pin was to prevent premature piston related damage, so maybe this could have been likely secondary to that. It’s sounds like a lot of people have had issues with the wrist pin, and it is a known defect from the early builds that is known by Mb so you might have some ammo to fight the case they should repair this at goodwill
Old Jan 1, 2019 | 11:56 PM
hmmwv's Avatar
2015 C300 4MATIC
Well crap, sorry to hear that. I think I have the wrist pin issue but the car has passed the original warranty date, so I'll bring it in for diagnostics at my cost, and see how much MB will want to repair it, and compare to the cost of an aftermarket extended warranty.
How much did MB want for repairing a cracked piston?
Old Jan 2, 2019 | 01:01 AM
Cali4niadriver's Avatar
W205
Yikes! I have a 2015 c300 too but had the entire engine swapped with a new one under warranty this past summer. I had the wrist pin done prior to the replacement, but I had my doubts after. Even when my spark plug damaged my engine the tech said it was a best case scenario to get it replaced. I have a feeling MB is going to have a lot of 2015 engine piston complaints in the near future, keep those receipts.
Old Jan 2, 2019 | 03:01 AM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
how do you know you have cracked piston ?
Old Jan 2, 2019 | 12:04 PM
dimbmw's Avatar
w-205
well, that is what Fremont dealer says it is... however not sending me a photo of a cracked piston after my numerous requests
Old Jan 2, 2019 | 12:05 PM
dimbmw's Avatar
w-205
i didn’t see the invoice yet but their original estimate was around $9K
Old Jan 2, 2019 | 12:11 PM
dimbmw's Avatar
w-205
i agree with you that if it is actually a cracked piston, it can be related to a loose wrist pin... that’s why I ask the Fremont dealer to email me the picture - if the piston cracked exactly at a joint with the wrist pin - then it would have been most likely consequencies of the wrist pin issue... if the crack is on top of the piston - then it may be related to a bad fuel injector (which is still under 70K miles warranty !!! )... in both cases in my opinion it should be covered by mercedes... but I think dealer figured out that I am an engineer and does not want to provide info.
Old Jan 2, 2019 | 12:13 PM
dimbmw's Avatar
w-205
spark plug damaged the engine? what !!???
Old Jan 2, 2019 | 02:08 PM
hmmwv's Avatar
2015 C300 4MATIC
Sounds about right, from what I've heard to get the wrist pin repaired out of warranty is about $7K.
Keep us posted about your negotiation with the dealer.
Old Jan 2, 2019 | 03:49 PM
DoorHandle_LED's Avatar
2015 C 300 4MATIC
60+% of new MBs are leased so Mercedes has little incentive to stand behind their product. They will probably give you a slight discount on the repair if you contact customer service and insist they help you. I fought for an extended warranty after I got my wrist pin repair done and they refused to do so.
Old Jan 10, 2019 | 08:36 PM
C300LEMON2015's Avatar
2015 C300 4 MATIC
Angry W205 Engine noise (like old diesel Toyota)
I cannot understand why Mercedes Benz is not taking this issue seriously. The w205 2.0L engine has design problems !!!!!My C300 W205 2015 was ok for 3 months. After that the engine was starting making noises under low revs like a diesel Toyota from the 80’s. My Canadian MB dealer ignored my complaints until the day the sound was so evident and they didn’t have excuses to no pay attention. The diagnosis was wrist pin issue. They replaced pistons, pistons bearings and connecting rods (engine less than 25 k miles).6 months later engine issues and car at the dealer. Diagnosis was a broken connecting rod. Big fight with the dealer because they were planning to replace just the failed connecting rod (What ???). Finally they decided to replace the engine (called big block) for example the turbo even it was exposed to metallic parts for the broken connecting rod was not replaced (info from the dealer: that's why you have an oil filter...). Car was 2 months at the dealer waiting for a new engine (come on guys, this is Canada, far away from the world).The new engine has now 53 K miles and my diesel Toyota SHOW UP again, yes the F… noise is there again (between 1700 and 2000 rpm) and it is so loud that you can hear it from the cabin. I went to the delaer and they said: it is normal and it is related to the direct fuel injection (maybe this is why they changed pistons and connecting roads before ???). BTW they told me: you don't have warranty now and further inspection will cost you $200 an hour (at least these are CAD dollars).This is incredible, I’m old enough to have several experiences buying brand new cars and in different countries. My ESL is from an underdevelopment country, but even in that country, the treatment of an issue like this one will be better of what MB Canada and USA are doing …I give up. For me is good to know what is the car brand I will never buy again. If somebody really knows what is that issue, pls inform that to MB.
Old Jan 11, 2019 | 08:01 AM
Redhook98's Avatar
2015 C300
Early builds? So later 2015 builds did not have this issue? I have 37k miles on mine, just bought it two weeks ago. It was manufactured in 10/2015. First I have heard of these issues. Are they common?
Old Jan 11, 2019 | 03:54 PM
jsbaker's Avatar
C300 4Matic
The problem was fixed around April of 2015 so you should be ok I believe. I had our 2015 checked yesterday that falls with in the date and vin ranges with 32K miles and was told we don't have the issue, atleast not yet. I've got almost 4 years of unlimited mileage warranty so I know when we will be trading it in.
Old Jun 22, 2019 | 12:26 AM
wlm44134's Avatar
C300
Thanks @dimbmw ,
It's real, many of MB 2015 C300(s) were imported to Taiwan from California , I bought one.
I heard about many cases of piston cracked, repair fee is around USD5K at Taiwan local maintenance plant .
My old Mazda 6 over 15 years, still working fine. How can MB C300 piston crack at 4 years?
As my image, US consumers are powerful than Asian's, how MB & government can ignore this issue ?
It can cause serious accident, it should be recall, right?
Old Jun 23, 2019 | 09:53 PM
riotrhythm's Avatar
W205 C300
What type of fuel do you use? Have heard from many MB mechanics that the turbo 4's will have a cracked 1st piston due to poor fuel. I.e. running 87 nonstop.
Old Jun 23, 2019 | 10:55 PM
dennish's Avatar
1992 MB 190E, 2016 MB C300
So this iissue is only on the 2015 C300. Is that correct? I just bought a 2016.Has this benn corrected in the 2016?
Old Jul 4, 2019 | 05:48 AM
Harold1898's Avatar
2015 E400 Coupe
Wha a worry for everyone who owns one of these. I feel for you guys.
Old Jul 5, 2019 | 01:44 PM
Cosworth2000's Avatar
2022 E53 AMG
What example is Wrist Pin?
Old Jul 5, 2019 | 04:34 PM
Terminator1's Avatar
W205 C250
Narrator: - "When I was a kid I had a dream about a car. Not just any car. It was a Mercedes-Benz... Brand new, shiny, fast, unbreakable... A Mercedes-Benz... I worked really hard to earn enough money to make my dream come true. Finally, I did it. In 2015 i went to a dealership... Just look at it! What an achievement! I was so happy and I enjoyed driving it. 50000 miles later I learned what a wrist pin is... A life changing event!"
Old Jul 5, 2019 | 08:50 PM
GreekUPS's Avatar
Only on some '15 C300's.
