Non OEM illuminated star (easiest wiring yet)
Old 08-22-2019, 08:48 AM
bngu1's Avatar
2019 E300
Originally Posted by Esandoval87
So I spliced the red wire to the grey/yellow wire from the driver's side headlight and the black cable to ground. But I can't get the star to light up.
Do you LED headlights? As some members had posted, different models have different wiring. You can always unplug the headlight and test each wire with the parking light turn on
Old 09-09-2022, 07:23 PM
maxcain's Avatar
2017 MB C300 4 matic
I read on another post to tie into a white and gray wire which turned out to be the high beam so when I use a high beam the star would come on I do not have LEDs only aftermarket but I would think the wiring would be the same as yours as indicated
[/QUOTE]
Quick Reply: Non OEM illuminated star (easiest wiring yet)
