Recent Command firmware upgrade, some changes
So I took it to the dealer and they updated the command firmware on my 2015 C300.
When I got the car back I noticed theses changes:
- The "Bluetooth Audio Devices" menu selection has been removed from under the "Options" menu.
- Bluetooth audio now has "Playback Mode"selection under the "Options" menu.
- The "Devices" menu selection (on the media screen) has now been changed to say "Connect Device" but it now takes you to the Bluetooth Audio Devices.
- I've also noticed that my trunk subwoofer bass (impact) has been reduced slightly. (I will re-calibrate sensitivity later)
- The center channel audio vocals seem a bit more pronounced than usual.
- Mid-tones now sound like someone is singing into a tin can. (echo)
- The command seems very slow to find Bluetooth devices when trying to pair. I now have to use "Connect via device" option to avoid waiting for a long time.
- The top menu options have changed.
- The "Activating Bluetooth Audio" background has changed.
**BTW, The firmware update didn't fix my issue with that device. All other devices work fine.
Old Firmware
New Firmware
Strange enough that same phone works flawlessly in a new 2018 c300. This is why i thought an update would help.
Now i need to debug my burmester audio sound quality issues from the update. I pulled the negative battery connecter for 1 minute last night to see if that would reset anything.
I will test drive later.
