Bluetooth Issues With Command - HELP!
- Won't find new Bluetooth devices two inches away from center console. I have to use "connect from device"
- Stuck on "device is paused" when using tidal. Tidal can be seen playing on the audio device, but no audio from HU.
- Plays music, but no title, album, track information is shown on HU.
- Takes a long time to "Activating Bluetooth Audio" when I start the car, then after I press "Connect Last Used Player", I get "Searching For Bluetooth Audio Device...", then "Activating Bluetooth Audio" AGAIN?.
Things I've tried to fix issue:
- Had dealer install software update. No Luck
- Purchased a new Bluetooth antenna. No luck.
- Checked wires. No Luck.
So, If I buy a new Head Unit (2059003919), Is their any special coding needed to sync with car?
( Apart from the latest software update )
