What is this discoloration?
Old May 28, 2019 | 04:45 PM
mazterofpupetz's Avatar
2011 E350
2016 c450. Discoloration around the trim of the windows. Is there any way to restore this?
Old May 28, 2019 | 05:18 PM
GringoBling's Avatar
C400
its hard water and it should come off with a clay bar
Old May 28, 2019 | 05:22 PM
2011 E350
That is a relief. I love the car, that was really my only hang up on it.
Old May 28, 2019 | 05:24 PM
C400
the whole car is probably covered in it, you just notice it on the black trim
Old May 28, 2019 | 05:28 PM
2011 E350
Wow thanks. Kind of removed my only reservation about buying a 37k dollar car.
Old May 28, 2019 | 06:37 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Black Magic or anything similar will make it look brand new
Old May 28, 2019 | 08:15 PM
fabbrisd1's Avatar
A gaggle of MB's
Well - frankly I have never found a product that will "remove" that type of corrosion on the trim even close to 30% - the majority of the corrosion is under the clearcoat...
Post pics if you have done it successfully
Old May 29, 2019 | 06:21 AM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
i got it replaced under warrenty.
if I recall, someone said it's due to brushless car wash.
Old May 29, 2019 | 07:14 AM
ygmn's Avatar
2015 E400 Sedan
Try washing, cleaning products etc then Slap some vinyl protectant on it very thinly and it will look good until next rain...
Sunshine, Crapy wash water, wash chemicals, environment, acid rain etc etc makes this happen...
Clay bar will not help as they are designed to remove BRake dust and other particles like stuff stuck in paint clearcoat.
Old May 29, 2019 | 11:53 AM
C400
clay bar removes all surface contaminates, including on glass.
things stuck IN clearcoat are not removed by clay bars
source: used to paint.
Old May 29, 2019 | 01:20 PM
dwpc's Avatar
2017 C300 Cab 4Matic
Looks like common staining of vinyl trim from detergent, hard water and maybe a harsh environment. It's likely in the surface grain of the plastic for good and will probably need regular treatment with a vinyl sealant forever.
Old May 29, 2019 | 01:26 PM
C400
heat can play a factor
I used to repair carbon fiber, and it was always worse anywhere that water could pool and then get heated off in the sun. That killed way more wings and hoods than anything else.
Old May 29, 2019 | 02:48 PM
ygmn's Avatar
2015 E400 Sedan
What clay is for:
https://www.meguiars.com/automotive/...-kit-g1016-kit
https://www.griotsgarage.com/product...ortby=ourPicks
"Paint Cleaning Clay lifts embedded contaminants, leaving behind an ultra-smooth surface that makes your paint shine bright"
Also removes overspray if not too bad.
Did the body shop thing and mechanic shop thing and detailing thing.
Old May 29, 2019 | 03:03 PM
bzammitt's Avatar
2015 Mercedes C400
Worked at a car wash for 5 years and saw this a lot from our chemicals. Waxing it helped iirc
Old May 29, 2019 | 06:28 PM
C400
What clay is for:
right, but if it is really IN the clear coat, clay is not going to take that out. It would have to be wetsanded. Maybe its semantics. And yes it removes overspray because it is not IN the paint.
Old May 30, 2019 | 01:05 AM
fabbrisd1's Avatar
A gaggle of MB's
In US under new car warranty "possible" to get replaced depends on how a dealer presents it to MB for approval... in US under Certified Warranty "not possible" MB will not approve.
This type of "corrosion" yes most often comes up with car wash detergents - hard water - salt water spray/air - anything alkali or acid that does not get rinsed off completely with neutral ph rinse water..
If aluminum trim is new or "good" - (1) wax/seal it just like paint - (2) lightly corroded Novus #2 Polish and wax/seal Step 1 (3) heavy corrosion #2 to get it a bit better then #1....
I have personally never seen a heavily corroded/fogged piece polished/redone like new - I could have my body shop polish the trim for a full day - still looks ****ty and will never "match" other trim pieces..
Old May 30, 2019 | 01:16 AM
2011 E350
I'm kind of hung up on it. 38k dollar car, I worry im only going to see this discoloration now.
Old May 31, 2019 | 12:04 PM
C400
Tell em 36k then
Old Jun 2, 2019 | 06:13 AM
jlr82's Avatar
2018 C300
It's from a combination of UV and chemical exposure over time. The car was likely not parked in a garage. All of the cars I've had that were unable to be kept in a garage most of the time eventually had this happen to various trim pieces. Nothing mentioned above will take it out. The materials themselves have become oxidized as whatever protectant layer is already long gone.
Old Jun 2, 2019 | 07:56 AM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
I agree. You're pretty much screwed on this one. Have seen this on cars before; replacement of trim is really the only good solution.
Old Jun 2, 2019 | 08:49 AM
bzammitt's Avatar
2015 Mercedes C400
Or spend a couple hundred bucks and get them vinyl wrapped black
Old Jun 2, 2019 | 09:34 AM
chassis's Avatar
2017 GLE350 4MATIC
Agree on the negotiation. If you want the car, and haven't already purchased it, find out how much new trim pieces cost, and deduct that from your offer. If they don't agree you can walk, or buy it at their price.
Old Jun 2, 2019 | 12:33 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Looks like the molding is from $100-$120 a piece. Vinyl wrap is a great idea too.
https://benzparts.autohausofpeoria.c...r-trim-pillars
