Replaced Rear diffuser and exhaust tips S205
Replaced my Rear diffuser and exhaust tips on my S205
The package
The parts
New diffuser bottom nd the old one on top
Before tearing apart
Startet prying off the old diffuser
Used a prying tool
The old duffuser off
The old exhaust tip mount
The new exhaust tip mount
Finnished mounting the exhaust tip mount
First test of exhaust tips
Finnished
Finnished
Finnished
Finnished
Finnished
Finnished
Differenc between old and new Diffuser
Here is a problem!!!, i have a Trailer Hitch, and the diffuser is to big comparing to the old one. I just took a chance, but i knew i had a problem. I am gonna try to find a good solution.
The package
The parts
Used a prying tool
Finnished
Finnished
Finnished
Finnished
Finnished
Finnished
MBSebas87 (09-17-2019)
The following 2 users liked this post by Andy74:
MBSebas87 (09-17-2019),
sentralfyr (07-14-2019)
Dissuser C63 on C43 S205
Hi guys, great work with replacing the rear diff. I am planning to do the same. I have all parts except the one in the red circle. Do I need that or can I just use the one from C43 diffuser? Or do I need it at all? Thanks for helping!👍
As far as i know, you can use the existing, i did without any problems
sentralfyr (09-15-2019)
So I have done it. Looks great. The only thing ist that in the middle section( red circles) the fixing points didnt fit(so it probably needs the C63 diffuzer part), so the diffuzer is fixed only on the blue signed spots, which i thing is enough. But I think its ok like that.
sentralfyr (09-20-2019)
If you go for the OEM original MB/AMG parts, there are different kits for cars with or without trailer hitch. (And also with or without night package)
For example: C 63 AMG FACELIFT DIFFUSOR C-CLASS 205 SEDAN & ESTATE WITHOUT NIGHTPACKAGE WITH TOWING HITCH
I went for the OEM C43 facelift diffuser/exhaust tips for my 2017 C43 S205 with trailer hitch and it fits perfect.
I think the Kunzmann shop, (in the link above), only ships to Europe, but it must be possible to find the same parts elsewhere if you live outside Europe.
