Would appreciate some audio advice.
I am driving a w213 and have been thoroughly enjoying the discussions made with regards to upgrading the Audio20 stock sound system. I've been looking at plug and play systems by rainbow / eton / groundzero
https://www.rainbow-audio.de/en/spea...line/mercedes/
As well as heeding the advice of mike who explained that without an aftermarket dsp am, spending the dough on expensive 2 way focal components is just not worth it as compared to going with mtx coaxials for the front doors.
I'm curious if these plug and play speakers would be better without amps as compared to just doing up the two way coaxials? I'm trying to go for value here as I am not the biggest audiophile.
Would also appreciate some advice for members who have opted to put a 6/8inch subwoofer into the driver's footwell, what were the amps and sub woofers you went with?
Thanks for taking the time to read and i look forward to your sharing!
The "top" DSP/amp combo in Match would be M 5DSP & M 2FX for the sub...
A more affordable twist - Match Helix brand PP 41DSP 4-channel w/DSP "built" as VW upgrade with correct integration cable for your W205 - some out there for bargain $200 - check with Fischer/Match distributor US Distributor to give you the correct harness/connector
Your suggestions regarding the sub and Amp looks good. But are those combinations able to fit into the driver's footwell?
