headlight strip different brightness
Old Aug 19, 2019 | 08:25 AM
SkumF's Avatar
W205
Hi
I noticed that the passenger sides light strip is stronger then the drivers side. Is this normal or any solutions?
I have no clue if light strip is the correct word, but it is the curved light that goes from blue to white when turning on the vehicle.
Old Aug 22, 2019 | 08:19 AM
MBOCD's Avatar
C180 Coupe (C205)=> C 300 Coupe (C205)=> E350E AMG (W213) => ??
This is completely normal for right hand drive countries. Passenger side is closer to the curve and has slightly longer light range.
Old Aug 22, 2019 | 11:11 AM
Doa's Avatar
Doa
W205
he means the DRL and no that is not normal
Old Aug 12, 2023 | 05:06 PM
Jake321's Avatar
Mercedes c300 2017
Anybody found the issue? Same here I replaced both module the ballast and drl module.. is there a way to lower the other side to make it the same brightness?
Old May 27, 2024 | 05:05 AM
Stage2400's Avatar
C400
reply
Jake321 or SkumF ??? Any Luck???
Old May 17, 2025 | 09:55 AM
SA01's Avatar
C Class W205
Originally Posted by SkumF
Hi
any one had any luck on this? Been searching the internet for days with no luck and no fix for this issue
Old May 17, 2025 | 11:12 AM
W205C43PFL's Avatar
Perhaps replace both modules, maybe the brightness will be consistent?
