Mercedes Rear Differential Oil Change
Old Sep 22, 2019 | 02:51 AM
Khanh Tran's Avatar
C300
Post Mercedes Rear Differential Oil Change
Anyone know how long we should change the Mercedes Rear Differential Oil Change on the 4Matic ?
Like this video below
Old Sep 22, 2019 | 07:51 AM
optimusprime m1's Avatar
W124 260E
Might help if you update your profile put in there the car you ask questions about ,.. So many models of Mercedes each have more than one way to change the final drive oil . On some models you are not able to remove the rear case in this video you posted , .And removal of the fluid will be through the drain plug . Now if you have these type plugs 1 to drain and 1 to fill .Dont remove the drain plug first until you know that the filler plug is removable . If the filler plug is stuck in place and not removable for some reason like rust ,then your will be stuck, because you have removed the drain plug and now you have no oil in the final drive till fill plug is removed
