Headlamp LED lens adjustment ?
Old Oct 16, 2019 | 09:10 PM
saurabhv's Avatar
W205
Question Headlamp LED lens adjustment ?
Hi guys, I just noticed the lens in my headlamp is pointing the beam downwards and I need to adjust the lens. did anybody adjust the LED lens on their headlamp ? And how to do that ?
this is the lens i want to adjust vertically
this image is taken from behind the headlamp assembly. can this panel opened for replacement of lamp in the led lens ?
Old Oct 16, 2019 | 10:24 PM
diamondsilver16's Avatar
2016 C300W4 (W205), Luxury Pkg, Diamond Silver Met. and Silk Beige\Espresso Interior
Found this in another thread:
Old Oct 16, 2019 | 10:26 PM
saurabhv's Avatar
W205
I saw this post. the screws mentioned in this post adjust the high beam not the LED lens.
Old Oct 16, 2019 | 10:30 PM
I don't think that's possible. The whole headlamp assembly appears to move up/down and left/right as a unit.
Old Oct 16, 2019 | 10:51 PM
saurabhv's Avatar
W205
here is a close up of how my lens is sitting in headlamp assembly.
Hey you are absolutely correct. I just verified it moves as a whole assembly on my driver side headlamp. But on this passenger side headlamp it is not moving as complete assembly. the height adjustment screw only moves my high beam reflector and the lens is just sitting at its lowest point touching the inside assembly at its bottom edge as its broken n fallen down.
any suggestions ?
Last edited by saurabhv; Oct 16, 2019 at 10:56 PM. Reason: forgot to add attachment
Old Oct 17, 2019 | 02:30 PM
GringoBling's Avatar
C400
that's a panel gap adjustment
That lens you posted is so jacked i think it might have broken inside though.
Old Oct 20, 2019 | 02:05 AM
Khanh Tran's Avatar
C300
I have the same problem. I broke the back and use my hand to push it higher. Then I glue them back. That is the only way to fix it Some time you are on the road and hit a Bump that cause the problem
Old Oct 20, 2019 | 02:17 AM
Khanh Tran's Avatar
C300
It happened to me 6 months ago. When I hit a bump on the road. My dealer say no way to fix that instead of change to the new one. I just try broken the back side then use my finger to push the metal up. They will stay there back to normal. It is the only way to fix them. Make sure you use a black plastic and a bond glue to seal them. I did not have any thing wrong so far wash my car a lot and they are fine til now. Good luck
The best bond glue ( black or clear is ok )
https://www.walmart.com/ip/Gorilla-G...ll&athena=true
Old Oct 20, 2019 | 11:12 AM
Kikas's Avatar
C 250 w205
good afternoon. I also have a problem with my headlight, it is illuminating 10% higher than the right, I can't manually lower it, is it possible with the software connected to the car to adjust the headlight through the engine inside the headlight?
