2016 C300 Sport Burmester Sound System Speaker Crackles
A few months back I purchased a CPO 2016 C300 Sport with 15k miles and the Burmester sound system. I kept noticing a crackling noise during the pauses between dialogue during podcasts and when switching songs. It sounds like crumpling a piece of plastic and it jumps between the two front speakers. Here's a video of the sound (make sure your volume is up). Interestingly enough, it happens whether you're playing something or not and on all inputs. You can start the car up, sit there, and the noise will emerge. It's worth noting that it doesn't happen every time and it's seemingly random (but pretty frequent).. Very frustrating.
I've been to the dealer multiple times. The first time, they changed the center channel speaker (despite saying that the center channel was not the issue). This time, they replaced the right front door speaker because, in addition to the cracking, it was making a vibrating noise during high frequencies. Turns out, even with a new speaker, it still makes the vibrating noise. They tested another 2016 C300 with the Burmester system and it made the same noise. This led them to test the other C300 for the crackling. Apparently, both cars make the same crackling noise. To me, this means they have two cars with a big issue, but to them, this means it's working as intended. So this is their answer: a car with a $50k sticker and the upgraded sound system just crackles and vibrates, and there's nothing they can do about it.
They also inspected the amp for corrosion or any codes, but nothing raised any flags.I'm wondering (1) does anyone else have this problem, (2) was there a solution, (3) and/or does anyone have suggestions on how to fix this.
Thanks in advance for your help!
There is a lot about these speakers in this forum.
I have 2016 with aluminum door trim, and I would say I need more high, the bass is too much. I drove 2019 C300 and it sounded different- more high and more crisp sound.
Attached is MB service invoice from this summer
Any how finally there changed the amp and the issue was fixed so it might be the amp sending in the power to the speaker when is not needing
Try replacing the amp
I just replaced all of the speakers in my car with Audiotec-Fisher Match plug and play sets and decided to debug and fully take care all noises.
https://www.audiotec-fischer.de/en/match/speakers/
I pulled one mid speaker off the door and plugged it in and played music with high frequency audio.
The speaker makes some of the HF noise when off the door.
it not as loud when off the door, but it's the speaker vibrating on highs. I had to put my ear very close to it. The new match mid speaker also does the same thing. Weird.
The metal trim clips will also vibrate, but I took care of that.
I've never heard any crackles.
I just plug in my headphones to verify that it's coming from the song on my device and not my car.
I learned that the hard way.
