blackvue dr750-2ch with power magic pro
Old Nov 27, 2019 | 10:37 AM
newc200's Avatar
mercedes c200
Hi all have a c200 with a blackvue 750 two channel and wanting some help with the magic pro part installation.
I've run the wires to the back of the boot to allow access to the fuse in the back and have used this wondering guide to help me hide the wires
Blackvue Install - MBWorld.org Forums https://mbworld.org/forums/c-class-w...e-install.html
I have brought some piggyback fuse taps for the magic power pro and wanted to know what amp fuse to put in ( is 10amp right for both constant on and the other only on with engine on ) and whether it should be placed near the wire side or the one furthest away as the fuse tap has 2 slots on each one. Both slots are currently empty and the fuse box pic is attached ( taken from the same site I got the instructions from)
Also does the earth just need to placed under the screw of the m8 bolt on the chassis.
And lastly the on the magic pro is it only the 2nd one to be down and the rest up for constant recording while parked ? or does this only pick up when triggered by movement etc.
Sorry new to all this..... any help would be grateful.
