10" screen install
Old Jan 21, 2020 | 06:51 AM
Louis Robinson's Avatar
C350e Sport Premium Plus 2017 W205
Question 10" screen install
Hi.
I have the 7" or 8" screen with Comand in my 2017 C350e W205 and was wondering if I can install the 10" screen easily as plug and play?
I've seen loads of post about Android and CarPlay etc. but I'm not interested in that, I would just like exactly what I have now but in a larger screen.
Thank You and sorry if this has been mentioned before.
Louis
Old Jan 21, 2020 | 07:30 AM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
There’s several threads about this. Try the search function.
Old Jan 21, 2020 | 08:05 AM
There are but I can't fine one that answers my question, they either don't say if it's a straight switch or they mention android.
Old Jan 21, 2020 | 03:24 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Originally Posted by Louis Robinson
Hi.
Louis
EASY is based on your DIY experience. There are several complete install videos on YouTube and here.
Installation requires you to remove your center console and head unit.
Are you comfortable with doing that? Then its really EASY.
Old Jan 21, 2020 | 10:53 PM
jeboo's Avatar
2018 C300 Sedan
Hi.
Louis
I believe what you're looking for is a larger stock screen. Do the 2019/2020 models come with one or offer as an upgrade option? That would likely be the only way to have a quick (2 screws + 2 plugs) swap; this also assumes the plug configuration hasnt changed as well. I'd guess they're pretty expensive to come by too, maybe call a dealer?
Old Jan 22, 2020 | 08:02 AM
Andy74's Avatar
W205 2015
I am not sure the oem 2019 screen will work on your car. And if it worked it will be very expensive. I recommend you make a search on Ali Express for aftermarket screen. I bought an aftermarket 10.25" screen. It works just fine good screen resolution. Multimedia ect... My car is C200 2015.
Old Jan 23, 2020 | 07:20 AM
Thanks for the replies guys, very helpful.
Ok, so including Android and what not, is there a 10" screen that will just plug and play? ie. 2 screws and 2 wiring clips and job done?
Old Jan 23, 2020 | 07:44 AM
Andy74's Avatar
W205 2015
In theory yes. The screen will be supplied with bunch of cables. If you are good in DIY then go for it. Sellers usually provide some guidance.
