Latest Australia Speed Camera POIs
Old Jan 23, 2020 | 05:03 AM
Mjollnir1983's Avatar
W205 C250 Sedan
Hi All,
For Australian Mercedes owners, I've made an update with latest GPX file with Speed camera POI.
The POIs are stored in GPX file, which you will need to load from SD card. I have created a 10s alarm before reaching the camera.
Total – 816 camera locations across Australia.
Original Guide
https://www.mercedescla.org/threads/...era-poi.12658/
Follow steps for installation depending if you have Comand Online / MBUX /
https://www.scdb.info/en/plugin-mercedes-comand-online/
Latest GPX file
http://s000.tinyupload.com/index.php...20262887888843
Source CSV
http://s000.tinyupload.com/index.php...19872692465173
Guide if you want to create / update your own
https://mb.jack-nicholson.info/
http://poidb.com/Groups/GroupDetails.aspx?id=58BD0059
Old Feb 1, 2020 | 02:29 AM
pussgalore's Avatar
na
I read the original mercedescla.org/ guide but am not quite sure I got this right.
I didn't get any pop up message saying that the data has been imported, and my COMAND didn't detect any files on my SD card.
However, I've noticed that now there are many speed camera POIs showing up on the map. I thought once the data was imported, the SD card could be removed but looks like it needs to stay in the slot? In any case this looks splendid. Thank you
Old Feb 1, 2020 | 02:33 AM
W205 C250 Sedan
The SD card needs to stay in the slot.
Do you have an audible warning before reaching the cameras? If so then it is working.
Also do you see camera icons on your maps?
Old Feb 1, 2020 | 02:47 AM
pussgalore's Avatar
na
I see. I haven’t driven yet but see camera icons on the maps now. When I go to options, under ‘alert when approaching’ both audible and visual are preselected, so it’s promising 👌 Look forward to using it
Old Jul 26, 2021 | 08:12 AM
Adrianm1957's Avatar
2020 c63 mags coupe
Adrianm1957
Hi just purchased a 2020 C63 Amgs. How do I get this file. Thanks
Old Aug 26, 2021 | 01:53 AM
blob2004's Avatar
W166 ML400
Hi there.
Any possibility that the GPX file link can be reuploaded/updated? The link seems to be dead.
Thanks very much.
