Rubber Seal Conditioner/lube
Old Feb 6, 2020 | 04:38 PM
89Benz300SE's Avatar
1989 300se/ 2016 C450 AMG
Does anyone have any recommendations on a rubber seal conditioner/lube? My sunroof and rear doors seem to be creaking in my C450. Thanks in advance!
Old Feb 6, 2020 | 05:03 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Gummi Pflege seemed to work for me. I’m not a fan of the application style but It does the job.
nextzett 91480615 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz
Amazon Amazon
Old Feb 6, 2020 | 05:08 PM
nextzett 91480615 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz https://www.amazon.com/dp/B004B8GTQG..._6ZipEb778XF03
Thank you! I read about this in another forum. I saw some reviews on amazon saying that the seals started to leak after applying this product. Do you have a panorama moon roof on your car?
Old Feb 6, 2020 | 05:50 PM
GreekUPS's Avatar
I have applied to my pano roof and just about every door, trunk, and hood seal. Never had any issues with leaking.
Old Feb 6, 2020 | 06:28 PM
Awesome! Thank you, I will order some and when it stops raining next week, I will put it on.
Old Feb 6, 2020 | 08:31 PM
DylanM's Avatar
C400
If it's creaking, also try Mercedes Sliding compound / Krytox. Permanent solution and safe for rubber seals / surfaces
Old Feb 6, 2020 | 09:39 PM
would you happen to have a part number or a site to buy it from?
Old Feb 6, 2020 | 10:00 PM
DylanM's Avatar
C400
You bet A0009893560 (dealers should stock it)
https://www.mercedes-benz-shop.ca/en.../p/A0009893560
It's not cheap, but you will never need another bottle - a few drops go a long way (and wear gloves!)
Old Feb 6, 2020 | 11:20 PM
GreekUPS's Avatar
Found a great price for US
https://www.mbpartscenter.com/oem-pa...ant-0009893560
Old Feb 7, 2020 | 12:15 AM
fabbrisd1's Avatar
A gaggle of MB's
Gummi Pfledge works great..... most folks I know pickup a tube of the Honda product. you use a vinyl glove to work it into the seals...
https://www.hemmings.com/blog/2019/0...aks-shin-etsu/
Old Feb 7, 2020 | 04:10 AM
Mikesmith2939's Avatar
C200 estate 2019 AMG line premium plus.
Gummi pfledge comes in two types a stick much like a deodorant or in liquid form with a sponge on the top of the bottle.
The liquid type is much easier to use.
Old Feb 7, 2020 | 05:15 PM
I will have to give the dealer a call and see what they charge for this stuff. Or shop around and see if I can find a good deal somewhere.
Thank you!
Old Feb 7, 2020 | 05:16 PM
https://www.pelicanparts.com/cgi-bin...n=A0009893560+
Maybe the dealer will price match it.
Old Feb 8, 2020 | 04:38 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Gummi bears?
Old Feb 9, 2020 | 12:06 AM
gonegolf's Avatar
Mercedes c200
I use Krytox too on the door seals and pano roof, very effective
Old Feb 9, 2020 | 10:17 AM
MBSebas87's Avatar
C300 Sport 4Matic
How often do you guys apply it?
Old Feb 9, 2020 | 10:20 AM
I apply Gummi pfledge about every 4 months.
I've had a bottle for about 4 years now.
Amazon currently have two bottles for under £20 delivered.
Old Feb 10, 2020 | 02:20 PM
GringoBling's Avatar
C400
Dielectric grease is the only thing that really lasts
Old Feb 10, 2020 | 07:21 PM
Is that safe for the rubber seals? I am not sure what dielectric grease is made of
Old Feb 10, 2020 | 07:46 PM
fabbrisd1's Avatar
A gaggle of MB's
Diaelectric grease is a type of silicone - sure a tube/can is under $10 - but frankly in silicone I would recommend speding $5-$6 more for the Honda Japanese made silicone designed specifically for door/sunroof seals..
Old Feb 10, 2020 | 08:05 PM
I ended up buying the gummi pfledge. If it doesn't work for the creaks I will try one of the other products suggested. Anyways, I can use the gummi pfledge to recondition the 31 year old door seals on my 1989 300se.
Old Feb 10, 2020 | 09:52 PM
fbsdmd's Avatar
2016 C 300 4matic Lunar blue
A good piece of advice was given here a few months ago. Don't open your sunroof in the deep midwinter, unless you are where it's warm.
Old Feb 11, 2020 | 12:19 PM
C400
yes, it is grease made specifically and only for rubber. It's used to insulate coil packs from the plugs.
Old Feb 11, 2020 | 01:56 PM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
The Honda silicone grease is very good. Learned about it in our Plymouth Prowler group and have been using it with great success. Available on line thru Amazon.
Old Feb 11, 2020 | 02:21 PM
Joseph~'s Avatar
2008 R320 CDI 4MATIC
FWIW......
I saw in one WIS instruction, MB had a official / recommended lubricant for rubber used inside the engine compartment, the item was part number 000-989-03-67 "Sliding Fluid - Mercedes-Benz".
For everyone's information MB published a document titled: "Mercedes-Benz Genuine Chemical Products" Product information for aids, operating fluids, accident and body repair - 66 pages, a PDF copy at :
http://www.w124performance.com/image...nformation.pdf
Regards
Joseph~
