Add keyless entry
I ended up ordering another handle and I have the last of four antennas to install at the passenger side. I already got it but it came without the connectors/pigtails, so I have to find those first to check if this solves the problem. I will report on the progress. Are you considering that install too?
https://www.aliexpress.com/item/4001059459142.html
Any update on this one?
I'd like to add keyless entry to my 2017 E220d w213, it already has keyless go. Main door is enough.
Has anyone been able to do a retrofit?
Sure. Will post my progress and if it works will also post some pictures.
For now I uploaded the manual of how to install this kit in a A177 car. The guide should also be valid for W205:
https://files.fm/f/tx4v8q49
Can you please upload this file again? The link is no longer valid.
Any update regarding the project?
#33
Anyone tried this install and has good news? I got a handle, antenna, wires and obd tool from aliexpress for my 2017 GLC (my car has keyless start not keyless entry) and used the obd upgrade tool that works via Wechat (all translated from chinese using a second mobile phone with a google camera translation) and connecting to the obd tool from phone via bluetooth to select the car model in the tool. I have chosen the installation of 2 handles (I only have one) and the tool did its thing without errors. However, it did not work. I tried using Xentry/Das to monitor the status of the handle in the keyless module and it is showing the change of status when the handle is touched inside (open) and outside(lock). The Chinise handle therefore works but there is a programming problem or a problem with key codea. Xentry indicates error because the handle in the passanger side is not present. I have searched the forum and found nothing specific, only some people trying to make additional keys to work with KG and some posts discussing that the key track should be 1 and 2 to work with keylessGO. if anyone knows where to program additional parameters in xentry please let me know.
