W205:16 C300 wheel/rim
So I found these rims that I like there 19in 8.5/9.5 rims with a offset of 35/38. Now I have a 2016 C300 base model with 17in rims all around rims with a offset off 48.5. Do you think the 19in rims will fit?If so how do u think they will look? Also any tires set up or brands u guys recommend. Thanks hope u guys can help me out
NOT MY CAR BUT THOSE RIMS
These rims what you guys think ?
I have similar wheels in 8,5/9,5 x 19. But they are ET45/50 (My base setup was 7,5/8,5 x 19 ET 44/52).
I think your ET will be too aggressive.
I have added some images of my car where you can see how they fit. Tyre sizes are 245/40 and 275/35
Nico Candelario (04-08-2020)
Your wheels are most likely 7,5" and 8,5" wide and ET 44/52, right?
This was my original setup as well and that will of course work fine on a C300.
But what Nico mentioned was that he was aiming for 8,5" and 9,5" width in combination with ET 35/38. That is 1 inch wider rim and 9 to 14 mm more aggressive offset.
This means front will be approximately 12,5 + 9 = 21,5 mm further out than yours. And rear will be 12,5 + 14 = 26,5 mm further out.
That will not look good.
Thank for
so basically going with that offset of 35/38 will not look good correct and probbly rub ?
thank for responding guys
just found another shop that’s has the same rims with a 45mm offset all around what you guys think ? Probbly the better option ? Will that offset avoid having rubbing issues ?
I'm currently running 19x8.5 +35 and 19x10 +35 on my w205 sedan lowered on springs previously and now on air. The front setup has zero issues even when lowered, so I suppose it should work if you are on stock ride height. The rears, however, are a little more aggressive and poke out a little bit. Although, I do have a difference of .5 on the width and -3 on offset so in my opinion, you shouldn't have any issues with a 19x9.5 +38. To be honest, I wish I had gotten some 19x9.5 +38 for my rears as I think that would have been a much better fit versus the 10 wides I have now.
Nico Candelario (04-19-2020)
this is what they ended up looking like w 35/39 offset 19in it on the aggressive side w 35/39 but I think it still looks great
Cordovian (04-19-2020)
Nico Candelario (04-28-2020)
