My review/installation of Audiotec Fischer Match speakers and amplifier - pic heavy
By using Nav zen tv and helix v8/v12, does it means that you take the Burmester amp/dsp out of the system? Will the new system be able to play surround like it means to be?
i have new Mercedes coming with Burmester 15 speakers. Wanna upgrade the system while keep it 7.1 to archive proper 2 seats tune.
i've been reading quite a lot. Came through this article from Musicar NW about upgrading premium Dsp sound system.
Basically, he suggest to keep the Original dsp/amp as a pre-amp and only use it upmixer. Then use aftermarket dsp/amp to drive speakers. Like Match or Helix V12.
https://www.adrenalineautosound.com/...enter-channel/
Is it the same thing you guy doing here? Abit confusing because you guys seem to take the burmester completely out.
''In theory, it seems like you could just tap the signal off the factory amplifier (to retain all the Logic 7 programming), and then send that to external amplifiers and better speakers. I don't even think you'd need a DSP - you'd just line converters with the ability to adjust the gain for each channel.
In reality, I have a hunch that swapping the speakers would change the dynamics of the system, and skew the Logic 7 programming.
In essence, you'd be replacing each and every speaker with a better quality, and adding more power (amplification) to drive the new speakers. The 'logic' in the Logic 7 system is probably programmed into the factory amplifier (maybe the head unit, but probably the amp). Either way, you would need to tap the signal (all 14 of them) off the stock amplifier, and run that into a multitude of external amplifiers, then feed that into aftermarket speakers. Same Logic 7 source signal, just amplified and driven into better quality speakers.
Seems simple, but as I mentioned above, I suspect that changing the speakers would also change the overall dynamics of the system, since all the original Logic 7 testing and programming was done around the characteristics of the stock amp/speakers.
I get what you're saying; reinventing the wheel versus diminishing returns... seems like a lot of work, for what isn't a guarantee of success. This is why I am such an advocate for the Mobridge unit. Granted, it only produces a 2-channel stereo signal, but it is an absolutely pure signal. It's like designing a system with a 'clean slate'. Kinda like trying to decide whether to invest a pile of money into remodelling a 50 year old house, or taking that same money and just building a brand new house. In the end, you'll get a get a nice new home, going either route - but it's a LOT less headache to build from scratch, rather than doctoring something that is existing."
First I just added a trunk sub (kept factory amp), then replaced and tuned 6 channels F L/R, R L/R and F LW/RW (kept factory amp), Then I moved to replacing all channels with a V12 DSP.
It's your choice.
- You can leave the factory amp in place, add a JL FIX 82/86 to flatten the signal (optional) and/or use a DSP AMP to flatten and tune the audio to speakers. If you leave the center and surround channels on the factory AMP, your movie audio is not affected much. You will lose fading in this scenario since input audio is only from fronts + subs summed to stereo.
- OR Remove the factory AMP, use a NAV TV ZEN-M, add a DSP AMP to tune the audio to speakers. The ZEN-M lets you input channels via TOSlink and RCA simultaneously. Put the TOSlink for fronts and RCA for rears and rear surrounds. You retain fading and surround audio. (according to the diagram below)
Which new Mercedes with 15 speakers? Make sure its listed on the compatibility list for Zen M.
BTW, you can tweak your distances (timing) to place audio (vocals) exactly where you want them. I use my center channel.
https://www.audiotec-fischer.de/en/k...tech-talk/ior/
The surround sound system in car is actually not for movies. It is for better music. I quote Andy Wehmeyer here:
"Better Stereo. Logic 7 and all other upmixers are designed to upmix a simple stereo signal into multichannel. Ambient sounds in the music are steered to the side and to the rear to increase stage width and depth as well as better reproduce a room. Left right and center steering are used to firmly plant the center image in the center for ALL of the passengers.
That's why. It isn't for movie playback.
Unfortunately, the OE system is tuned to put the center image directly in front of each passenger, there isn't enough power and there often isn't enough bass."
i'm afraid none of those 2 choices u mentioned is what im trying to find out.
My car is 2021 g63. Last time i check Zen M is suitable.
A - Keep the OEM amp and use it as a decocder and the v twelve sits between the OEM channel output and speaker to provide marginally more grunt. You can 'de-eq' the inputs to the helix if you want to remove the factory curves to run different speakers, for example the focal drop in kit sounds hideous with the factory EQ still in place.
B - Use a Zen-M in place of the amp which then gives you the same channels but as a line level output without any speaker compensation curves. Content channel by channel will be the same just flat in its EQ curve and cleaner without the extra amp stage.
So yes the Zen-M is completely optional, but provides a cleaner signal path. Focus on my car is a solid stereo performance so I like the idea of keeping the source in the digital domain all the way to the DSP, and cutting out any unwanted factory EQ I'd then need to counteract.
Each to their own when it comes to 'up-mixing', my home Lexicon processor and the car support logic 7 and to my ears it just sounds like a layer of cheap reverb effects. I know ambisonics and psychoacoustics have come on a long way but the vast majority of music is mixed and mastered in stereo, so I listen to it as it's intended,
As for not time aligning 7.1 I'm not sure the reasoning, ultimately a cars driver seat is a pretty awful place to run surround sound given you're too close to the front stage, sat equidistant between the center and one of the front mains (depending on LHD RHD). However in the studio spaces I've built, unless you're getting your speaker placement in a perfect arc you'll always time align to phase align the sub 500hz - be it with a Trinnov or something like GLM. Time / phase alinging all the channels is only going to be a good thing, that is unless they're already aligned and you're just throwing them out by double adding the distance factor.
Looking at the G63 it has 16 drivers from 10 channels:
Seems to break down as:
1 - roof tweeter - CHAN1
2 - Roof mid - CHAN1
3 - Left tweeter - CHAN2
4 - Left mid - CHAN2
5 - Left Woofer CHAN3
6 - Right tweeter CHAN4
7 - Right mid CHAN4
8 - Right Woofer CHAN5
9 - Rear Left tweeter CHAN6
10 - Rear Left mid CHAN6
11 - Rear Right tweeter CHAN7
12 - Rear Right mid CHAN7
13 - Surround Left CHAN8
14 - Surround Right CHAN9
15 - Subwoofer CHAN10
Do you run central speaker with your route B upgrade, Muu? why/why not use central speaker in this case?
Could you post ur plan drawing diagram? Look like ur system and mine pretty much the same. Thanks a ton.
Can do some schematics tomorrow (late now here in UK)
Yes I run a center, going to try it out but fear it'll head for the bin in exchange to run the tweeters active, maybe some md102 like in my GT3
In case i keep central speaker on roof. Does it mean the sound stage will raise high to the middle point for both seats? Will it be somewhere in middle of 1 and 2 speaker?
I've told that it is pretty complicated to tune 2 seats set up.
I want to run all active, so i need 15 channels, add 1 more supp, it is 16 chanels. Use zen M to zapco V 16 channels. Is it sounds right?
From there you can engineer a solution based on either a symmetrical surround approach where you use the same drivers all round (crucial in immersive systems), or you bias your attention and funds to the front stage.
I do have a center speaker with a mode switch up front, mode 1 being a family setup designed around a 2 seat tune with the center processed in the helix, mode 2 being a selfish tune time aligned to me with the rears all but off.
For context I was a sound engineer by trade, but work in broadcast systems now. I do however have a preference for flat 'studio style' response, Vs the more sparkly audiophile tastes. Personally I love the dynaudio car stuff, and if I had your car I'd be rocking a complete active esotar setup 110+430+650+1200 with a standalone helix DSP and quality amps.
I heard a lot of good thing about Dyn, unfortunately the tweeters too big. Cant put it in OE location.
My mind alot clearer now. Thank you guys for spending time and explain it. Appreciated.
Head Unit >> ( OE Amp: MOST150 decode >> EQ >> channel filter >> DAC >> channel amp) >> (helix amp: high level stepdown >> ADC >> de-EQ >> custom EQ >> xover >> DAC >> channel amp) >> speaker
However still feel with the money you're plowing into this it'd be nicer to have the clean signal the ZEN-M provides, no unwanted EQ and a digital path for the front stage & sub.
You could use the MD102 with the Esotar 430 & 650 no issue.
Downside is losing surround.
Upside is cleaner signal hence better sound.
Will seriously consider Dyn. In case go with Dyn, i should have A-B amp then. What would the system be like? Would i still be able to have 2 seats tune mode?
Mode 2 seats tune: helix V12 drive all speakers
Mode 1 seat tune: Helix C4 drive front 3 ways? Ignore central speaker?
a bit confuse.
a bit confuse.
With a mode switch you can have 2 setups, with a Helix Director you can have up to 9.
Depends what you wanna spend really, arguably you're beyond what a integrated DSP amp is useful for and should look at a dedicated DSP like the Ultra.
Spend An evening listen to Esotar. Im sold. Will do actual demo tomorrow but im more than 90% sold.
Will build system from there. First is the quest to buy 1 and a half pair 🙄
Btw, would it significantly different using M102?
Thus im pretty sure on Dyn Esotar, Zen M, Helix Ultra. Still go after mid channel and 2 seats tune.
Suggest amp?
Big thanks on this Muu. Appreciated
My 911 runs MD102 E430 MD172 as an active 3 way
You could make an exposed 110 work but a md102 easier, with 430 + 650 in the doors.
Amps wise, depends. You'll find the woofer the limiting factor, you'll have that at 0dB channel trim turn pull 4-6dB out of the mids to align them given equal power. The helix V12 certainly is neat, coupled with its extra outputs for a dedicated sub amp. That said be nice to have class-AB for the front stage, at least the tweeter and mids anyway. Then class D for everything else. Hence why standalone DSP are nice to mix and matCh, given funds space and time.
but something was not right. Thus i thought it would be wise to upgrade step by step. But now i think i find what i like.
This Esotar just sing so well, smoth, effortless and i feel it so relaxing and has a "high-class" sound. My vocabulary is not enough to describe it. I think im hooked. This car is a keeper, wont carry much, thus space is not limit factor neither. Now i just need to carefully chose equipment and installer. Glad you help man. Appreciated.
This is the channel has sound i like most this evening
