Steering wheel knock
Old Apr 19, 2020 | 02:35 AM
Compfreak's Avatar
W205 amg line estate
Hi hope some one could help me out.. two weeks ago I've noticed a slight but noticeable knock while turning the steering wheel.. it's coming from the steering column it self. Does it at stand still and while driving.. there's no play or movement when I pull on the steering . Maybe it could be something else..
any help would be appreciated.
Old May 4, 2020 | 11:49 AM
Appealin's Avatar
2016 Mercedes C300 W205
Steer wheel knock
I had the same situation, it’s the airbag bracket in the steering wheel. Needs to be readjusted. Check the dealer. I had to go to three dealerships, the first two said it was normal. So just tell them to check the airbag!
Old May 4, 2020 | 02:28 PM
kevinmelone's Avatar
2015 C300 4-MATIC Sedan
When you guys are referring to a knock, is it a slight resistance/bumping feeling when you turn the wheel?
If I slowly turn my wheel to the left, I can feel three/four little knocks. Want to make sure I’m following the right thread!
Old May 4, 2020 | 05:42 PM
Appealin's Avatar
Steering knock
In my situation, it would knock when I turn left to right! I would check the airbag bracket first!
Old May 5, 2020 | 02:02 PM
Compfreak's Avatar
Is there any way I can do this myself or is it only something a dealer can look at..
thanks
Old May 5, 2020 | 03:14 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
I remember there was some kind of steering bolt recall service campaign recently. Hopefully it has nothing to do with that.
Old May 10, 2020 | 12:15 PM
Compfreak's Avatar
Just seen this on gov.uk site this mite be the issue with mine.. ill ring them and check my vin with them
Old May 10, 2020 | 01:22 PM
Appealin's Avatar
That’s for w204 models. This is a w205 forum!
Old May 11, 2020 | 12:20 PM
Compfreak's Avatar
My bad... spoke to mercedes today and I have two outstanding recalls on my w205 so will get them to sort this out when I take it into them..
Old May 11, 2020 | 12:33 PM
Appealin's Avatar
That’s good! What year is your car? What recalls?
Old May 11, 2020 | 02:38 PM
Compfreak's Avatar
2014
ecu and knock sensor
Old May 11, 2020 | 02:46 PM
Appealin's Avatar
You have a coupe? 2014 C300 sedan is w204
Old May 11, 2020 | 02:55 PM
Compfreak's Avatar
Estate
It is what it is.. ill get mercedes to fix it
Old May 11, 2020 | 05:20 PM
Appealin's Avatar
That’s w205. Looking good too. They’ll fine the problem, hope it’s not too costly. Hopefully the recalls do the job
