W205 2015 C300 LED DRL right side not working
LED DRL right side is not working
Hi guys! The LED DRL on the right hand side on w205 2015 C300 stopped working 2 days after it rained. I got some water drops/fog inside the headlight which made the DRL flicker and the turn signal stopped working. A day after the turn signal is working fine and when I start the car the DRL blue light come on For a couple of seconds but the white never comes on. So at this point it seems that everything in the headlight is working except the white LED DRL. After reading and researching, it seems to me that it’s a controller issue and hopefully a controller replacement will fix it, but there’s 3 controllers on the headlight and I’m not sure which one I should get.
I tried finding a phone number for Otto auto but didn’t find one so I emailed them twice but no reply..
does any one here knows which controller I should get? Or if it’s actually a controller issue?
thank you!!
thank you!!
You should really use the search feature to find your answers first but anyway, look here.https://mbworld.org/forums/c-class-w...w205-c180.html
thank you!!
thank you!!
hey buddy i have w205 2015 model. My headlight day light is not working during the day i wonder if its normal? It only turns ON when its getting darker... is that normal for 2015 w205
if you are talking about the daytime running light, if both are not working, check your settings. In the US you can usually turn them off.
thank you!!
thank you!!
Any update on this situation I’ll appreciate any information thank you
Received 2,453 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Similar issue by chance? https://mbworld.org/forums/c-class-w...ght-led-2.html
In Canada you can not turn of the DRL as it's the law for some time that DRL must be active during the day.
For me, I have no errors in my Left Light module however at night I have noticed that my left side only has 1 light on and on the other side - right side - I have 2 lights on the right.
Anyone noticed this? When I test the high beam, they works perfectly. When I check and test the movement of the lights, it works perfectly and lights of the blind spot.
I was not able to turn off the lights during the night time as they stay own unless you are in park for a few minutes then they will turn off,
I scanned the module and the temperature looks good, the fan is working, there are no codes for the light being out. It looks kinda weird that 1 light is out on the driver side. I may have to look closer since I have the Multibeam lights and they should not be any maintenance.
Yeah I played around with the light switch and that did nothing except make the back lights turn on the fog settings.
I scanned the module and I temperature looks good, the fan is working, there are no codes for the light being out. It looks kinda weird that 1 light is out on the driver side. I may have to look closer to since I have the Multibeam lights and they should not be any maintenance.
I see, good luck. Hopefully it is just a software glitch, I don't think this will work but doesn't hurt to try have you unplugged the 12V battery for 10 or 20 or 30 minutes, checked the aux battery's condition and see if it just resets itself?
Any update?
