DTC codes P0339 and P0039
That’s a different crankshaft sensor than the ones I replaced, I wonder if the diverted valve code comes in because of blowoff valve
for P0039, it might be your blow-off, but usually this code doesn't light up as a CEL. I still have this same P0039 code for a long time, as i am using the Turbosmart Kompact.
Deal with the crankshaft sensor first. Part number is A2709050600. This part is shared with the M270 engine platform as well.
appreciate the help I got that sensor ordered and going to put it on next week, hopefully get to the bottom of it
The car runs perfect on the stock tune but when I change it to the Stage 1 tune I get hesitation around 2-3K RPM and I checked the codes and it shows P0039.
I did have a TurboKits VTA BOV "whoosh" valve installed I removed it and I still get the code. I am not sure if I damaged anything in the diverter valve when removing the BOV? Or is this anything else I should check?
Or is there anything else I should check?
I did contact AMR they advised to take it to the dealer. Since others had this issue before I would be interested in the fix for this issue?
