Steering wheel vibration
Old Jun 10, 2020 | 12:47 PM
Nico Candelario's Avatar
Veteran: Marine Corps
2022 E350 Benz
So I have 2016 c300 with aftermarket rims 19in when I received them they were already balanced. But when I drove the car I notice that my steering wheel was vibrating At 60+. Took it to a shop they rebalanced the tires it was worse. Took the car to the dealer ship they rebalanced and inspected the car I told him I was having that issue. He said we fixed it and that it still has a slight vibration but overall it wayy better. I test drove it and again at 60 mph it had a slight vibration like he said witch was better then wat I had but it’s still there and annoying . But I also started to notice that when braking Pretty hard the left side/ bottom of the steering wheel starts to vibrate/shake then goes away as I slow down but happens Around 60 again this dosent happens every time only when it want to it’s werid. Tested it on a brand new paved road. At 60 my steering wheel still has the slight vibration and maybe that can’t be fix fine. But as for the slight shake of the steering wheel when braking it woundering what it could be I drove on that road twice first time no vibration when applying the brake second time the steering wheel started to vibrate
I have no idea what could it be any suggestion
I have not check brakes or rotors but the shaking is only happening when I apply the brake SOMETIMES.
Old Jul 23, 2020 | 04:50 PM
belarus27's Avatar
2010 e550 p2
I have a similar situation with my w212.
gonna take it to a shop next week
Old Jul 24, 2020 | 12:43 AM
LaciCLK320's Avatar
C300, CLK320(sold)
Possible solutions:
1. Put your old rims back and see if they are vibrating at 60+.
2. Put you new rears to the front and see if its doing the same thing at 60+
3. Could be a bent rim.
4. Road force balance.
5. If 1-4 fails then it is the suspension or tie rods.
My 2 cents.
Cheers
Old Aug 19, 2020 | 11:49 AM
Marian Stroiu's Avatar
C Coupe W205
I had this issue when I changed my tires and I had to buy new ones because were bad from the factory.
