W205 communication problem between differend ECUs
Old Jun 18, 2020 | 11:03 AM
totu1111's Avatar
mgLipGD
Hi guys,
i need urgent help!
my car is w205 C class. I was retrofit programming ILS to my w205 by a mechanic. He was using dts monaco. There was some problem happened and them, my car is full of communication problems according to xentry.
errors are between Ecus of steering column, engine, tpms, and so on. My HU does not work and also, there is no power in 3 large fuses of front passenger footwell. I remember once one of them blown, cAr was full of errors as well. And now, there is no power on them as well.
i made scn coding for :Front SAM, Electric ignition lock, ESP, A/C, Shift Module( i dont remember exactly its name) and it did bot work. I reflashed Eis222 through dts monaco with same program version. And nothing worked.
Rightnow, engine starts, however, no button works except Windows controls. Car does not shift, does not shift neutral. My garage is long and height is 2.2m. I cant order trailer to take it to mb dealer because it is going to damage many prts as it does not shift to N.
What can be main problem guys? It is clear that something does not work and that is why there are full of communication errors. what can cause this problem?
can someone fix it through teamviewer? I can pay to someone that can fix it.
can be front SAM cause this problem?
i upload some error photos, sorry if i broke rules
Old Nov 26, 2022 | 12:51 AM
julio2535's Avatar
W205
Hi,
Did you finally fin a solution ?
Old May 23, 2023 | 10:26 AM
Binha349921's Avatar
c250 w205
SAME DEFECT
Originally Posted by totu1111
Hi guys,
i need urgent help!
hey did you solve the problem? I have the same symptoms. I suspect it's the sam module
