Needing advice resolving error codes after w205 rebuild.
Old Jul 19, 2020 | 12:27 PM
Eni Xh's Avatar
c class
Hello fellow mercedes owners. I just finished rebuilding my w205 c300 sedan lhd, it was side swiped from left b pillar, rear door and quarter panel, only airbags that were deployed was curtain and seat ones, replaced them, the seatbelt works fine, extends and retracts fine. When i went to Clear the codes and i am stuck with 2 codes that wont clear, the codes are:
B007E13 The squib for emergency tensioning retractor “Driver” has a malfunction. There is an open circuit.
B1EAF97 Easy entry/exit has a malfunction. The system function is restricted.
Error Code
Dashboard error
I cant seem to find a fix, i am worried to drive the car because the airbags might not deploy in case of an accident, please if you have any suggestion let me know. I really need help with this.
extra error i get in the dashboard is Active blind spot assist inoperative, when the car is in ignition 2 the triangles stay red.
any help is highly appreciated. Any additional questions let me know ill try my best to provide any information.
Old Jul 19, 2020 | 12:51 PM
places's Avatar
No more MB:(
These are very complicated machines. Take it to the dealer.
Is your safety really something you want to take shortcut on to save a couple dollars?
Old Oct 28, 2020 | 11:42 PM
nearcomike's Avatar
2008 E320 BlueTec
Could it be a swirl flap motor?
Old Oct 29, 2020 | 02:04 AM
irondad's Avatar
W205, X253, C190, W213,
Dude.
Old Oct 30, 2020 | 10:25 AM
Cosworth2000's Avatar
2022 E53 AMG
If this was a crash registered in the system. Most modern cars need to SRS to be reset as well as the seatbelt to be reset. Nothing will be plug and play without these to features being reset.
Old Sep 4, 2023 | 10:26 AM
chaua's Avatar
C class w205
Hi,
I am currently also experiencing this issue. Got a B007E13 fault code. I have changed out to brand OEM airbags and reset the airbag module.
Did you end up resolving this issue? If so, what was your resolution.
Thank you in Advance
Old May 10, 2025 | 07:52 PM
yyrikz's Avatar
w213
Originally Posted by chaua
Hi,
Hello, friend. Did you manage to solve it? I also have this problem and the airbag has already been replaced.
