Auto Start/Stop Stupid?
So the ECO operational algorithm - to meet EU requirements - is a International Conspiracy on the part of the 3rd largest auto/truck makers in the world to accelerate the wear on your C-Class ?
So that you know the operating temperature of 10W40 is -30C to 100C - so what is your beef that engine technology has changed since the 1970's ?
Stupid Is What Stupid Does - you should get out more buddy...
My 02 Corvette z06 I don't gun until the oil temperature reaches 145 degrees Fahrenheit, because it's widely understood this will cause premature wear on the engine. It takes a good 10 minutes of driving in warm temperatures to get there. It's a big 5.7L v8, it's also not a 1970's...
Operating temperature means the oil will function in those temperatures, not that its the optimal operating temperature. Would you really feel comfortable if you were turning your engine on and off with oil at -30 Celsius??
I'm all ears and if there's something I don't understand about something I love learning new things. But your response come across like you've got something to prove and you're an *******. Just saying
Unplugging that two-wire sensor at the negative battery terminal was one of the best "mods" I've done to my car.
None of these comments are called for...
AFAIK, modern engines really require no warm-up anymore. This is more a less a thing of the past. Same with the cold starts in the winter; start the engine and get going. One of the ECO parameters is the coolant temp; not sure if oil temp is a relevant for engine condition.
Personally I disable the feature the moment I step in the car
ECO start/stop is a much disliked feature, similar to run flats, but it has been around for many years, installed in millions of Mercedes models.
If there would be potential engine damage related to it, including high mileage engines, we should see many thousands of issues popping up.
Not saying it can’t happen but I haven’t seen such a thing.
If you get "tired" of it - Vladimir in Belarus (righteous guy) for like $180 his OBD module reprograms ECO so that if you have ECO-Off when you turn off your MB - when you re-start your MB ECO-Off. If your turn off your MB with ECO-On then when you restart your MB ECO-ON - and that ECO setting will not change if you change profiles during your drive.
Like $180 for W205 up thru 2018 : https://www.ebay.com/itm/MERCEDES-ca...EAAOSw2iJa-n9S
A bit more if have 2019-20.. check other eBay listing.
eBay message Vladimir your VIN FIRST so he can confirm back to you.
It's all software controlled.
On this model the negative battery thermal connector disconnect also renders brake HOLD disabled , which I like .
Having run with the fuse removed for several months now I went the full hog and removed the auxiliary battery saving 5kg and the ability to sell it to the Mercedes OCD types that must have everything functional even though it may be a bad thing .
