Useless Taillight Mod
Old Aug 8, 2020 | 12:30 AM
diamondsilver16's Avatar
2016 C300W4 (W205), Luxury Pkg, Diamond Silver Met. and Silk Beige\Espresso Interior
Another chapter in pandemic boredom.
I have my original 'halogen' taillights (which I prefer), but they contain separate turn signal bulbs that are both physically and electrically disconnected from the factory for the US market.
The bulbs are old school filament PY21W type of the amber variety. I thought, what else can I do with this space?
So I bought some red LED PY21W bulbs and then wired the sockets into the existing brake/turn circuit.
The blue arrows indicate the negative side circuit of the bulb socket. These are punched out from the factory at the rectangular hole in order to disconnect the circuit. Now reconnected with solder.
The yellow arrows point to jumper wires I added to connect the positive side of the bulbs to the brake/turn circuit. The existing connections were terminated with the assistance of my dremel cutter wheel. (Simply reconnecting the original traces does NOT result in functional amber turn signals.)
The effect is subtle and gives a little more visibility when I brake. Otherwise it's completely useless.
Old Aug 8, 2020 | 02:36 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
@diamondsilver16
You should try an led taillight upgrade.
https://www.aliexpress.com/item/10000188253057.html
https://www.aliexpress.com/item/4001153199394.html
Old Aug 8, 2020 | 04:38 PM
You're missing the point here
Old Aug 8, 2020 | 05:27 PM
benzdude's Avatar
Top Answer: 1
Sorry, you said you were bored.
https://youtu.be/-obuY7_aF7U
Old Aug 8, 2020 | 06:04 PM
As far as taillight upgrades go, I actually prefer the 'basic' version with the single light pipe that follows the trunk line instead of the double loop on the full LED version.
The facelift taillights look too much like a Nissan Maxima to me.
If an aftermarket comes out with a more unique look I'd be interested.
