Android 10.25 New UI(2020) boot load problem
I want to put a mercedes logo for the boot load part, but somehow I couldn't. Is there anyone who can help me with this issue?
In which directory should I put the bootanimation.zip file?
info on the usb drive, size, format, folder structure screen shot
Without all this info we cannot help as we don't where the problem is
anyway try the file below and see if is working......have your USB below 32GB and download the file below and Unzip and Select the USB drive Location.....
so you USB should have only OEM Folder in there after unzip nothing else.... then Insert the USB to android Device and then start the device after while it should automatically upload
how do you import a splash image?
by the way the steps i will describe for this is in your own risk!
This morning I have tried to install animated logo in my 12,3 Inch screen following the instructions of this post:
From configuration I tried to change the logo but it doesn't work neither.
I only want to install a new logo, non animated if it's not possible with animated logo.
Could anybody please help me?
I wanted to see if you could help me. I changed the startup animation by putting the zip file in the OEM folder at the root of the USB. It changed it without any problem. Now I don't know what's happening. I put the file the same as before in the OEM folder and it doesn't do anything, it doesn't change. What can I do to be able to change it again?
