Tires
Old Nov 21, 2020 | 09:54 PM
Brittnie Jane's Avatar
2019 C300 Coupe AMG Sport Package
Tires
2019 C300 Sport Coupe
I need four new tires already, what do you all have on your coupes? (Please specify if they are run flat or not)
Old Nov 21, 2020 | 10:58 PM
dwpc's Avatar
2017 C300 Cab 4Matic
I had OEM Continental run-flats on my Cabriolet until this week, when I had conventional new winter tires mounted. The softer tread on the winter tires may account for some of the difference but the improvement compared to run-flats is huge; far less jarring over bumps, smoother, lighter steering, and very much quieter. And that's with 2 psi over the recommendation. Though my run-flats tires still have over 50% tread left, the difference is so striking that I'll probably replace them with conventional tires when the winter tires come off in March. Carrying a 12V compressor and road insurance since there's no spare, but I can't remember the last time I had to use a spare tire.
As for specific tires, I don't want to start a food fight, but it's pretty hard to go wrong with Michelin or Continental. For LA driving (I'm ex NOLA), I'd recommend tires with the best wet performance over a general high performance tread. All-seasons won't gain you anything in a warm climate. TireRack.com is a great resource for tests and reviews.
Old Nov 22, 2020 | 03:50 PM
I’ve repeatedly seen on the forums that switching to a non run flat makes a ton of difference in noise and drivability. I was looking at Continental on Tire Rack!
Thanks!!
Old Nov 22, 2020 | 09:36 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
Thanks!!
get the Continental DWS 06. Non-runflats
Old Dec 1, 2020 | 08:54 PM
Seem to be highly rated
Old Dec 2, 2020 | 08:35 AM
mikec35's Avatar
2016 C300 sedan
How many miles did you get out of the current set? Are the fronts or rears worn more than the others? I've gone through about 6 sets of tires. The original Continentals I had lasted the longest but were the noisiest and roughest riding. My rears wear out before the fronts - the outer edge wears out around 15-20k miles and they start getting noisy. I'm currently running Pirelli P7 run flats because I got a smoking deal with them already installed on another set of factory wheels, they are ok. Honestly, with all the sets of tires I have had on this car I really cannot tell any major differences between the different run flats and non run flats other than noise and harshness .. all the run flats seems to run about the same and all of the non run flats seem to run about the same. Looks like you are in Louisiana, I think any decent rated Summer tire will work well for you. If you are happy with the originals and they lasted a long time then I would consider going back with them. If you are looking for budget tires don't be afraid to get something lower priced as long as they are a good name brand and don't have any crazy negative reviews. Just remember, if you have non run flats and get a flat you will be waiting for a spare tire roadside repair or a AAA tow.
Old Dec 2, 2020 | 09:40 AM
hyperion667's Avatar
2012 CLS63
Do you happen to have a Discount Tire near you? I'd recommend them over Tire Rack
Old Dec 2, 2020 | 10:32 AM
mikec35's Avatar
2016 C300 sedan
I recommend Discounttiredirect.com as well. If you order from them online then go to one of their stores to have the tires installed and something is wrong they will take care of you. Order from another vendor and find a problem with the tire at the installer then they won’t cover someone else’s tire. There are also rebates for Discount tire if you use their card, which I got specifically for the rebates - I don’t use it for anything else but tires and pay it off quickly to avoid paying their high interest rates.
Old Dec 2, 2020 | 01:06 PM
dwpc's Avatar
  • Unless you expect to be driving in light snow, my advice is to stick with summer tires with good wet ratings. All-season tires are a compromise and are a noisier.
  • What they don't tell you about run-flats is that by the time you drive to the tire shop on the flat tire, that tire is usually trashed and you'll have to pay $200 for a new tire.
  • If you don't buy runflats, consider carrying a small 12V compressor in case you get a slow leak. I carry a small Black & Decker compressor that I can also use to inflate my paddleboard. Alternately, you can carry a couple cans of "Fix-a-Flat" but some tire shops may refuse to fix a tire that's been filled with sealant goop.
  • There's no spare, so a serious leak or blow-out with non-runflats means a flat-bed ride. It's unlikely, but stuff happens. If M-B or your insurance don't cover it, consider adding it or getting roadside insurance just-in-case.
Old Dec 2, 2020 | 07:22 PM
I was at 19,000 miles when they told me that I needed new tires, I had probably needed them for a while. My Mercedes dealership said that my rear two and passenger front tread is a 3 and my right front is 0...I found that odd?
Old Dec 2, 2020 | 07:42 PM
2012 CLS63
Not that odd, MB's EAT tires.
Old Dec 2, 2020 | 08:20 PM
mikec35's Avatar
2016 C300 sedan
Yep- I got 40,000 out of my first set of fronts, my rears were making noise at 15,000 and I replaced them at 20,000. You can look for tires that have longer tread wear life/rating but they are usually harder rubber, translating into a rougher ride. Too many considerations and choices! Good luck
Old Dec 2, 2020 | 10:09 PM
$771 on Tirerack
$852 on Discounttire
Old Dec 3, 2020 | 08:22 AM
2012 CLS63
Question
$771 on Tirerack
Price difference is negligible in this case. What sort of guarantee does TR offer?
Old Dec 3, 2020 | 11:40 AM
dennish's Avatar
1992 MB 190E, 2016 MB C300
I am quite picky and hate tire noise more than most, and I have to say that the original Continental run flats are quiet and nice riding. I think this is because I have 17's. My past car was a w204 with non run flat 18's and all the tires I tried were noisier than these Continentals.
Old Dec 3, 2020 | 11:00 PM
FREE TWO-YEAR
TIRE ROAD HAZARD
PROTECTION
  • Repairs reimbursed up to $40 per tire per occurrence.
  • 100% reimbursement of the original cost of the tire during first two years (if not repairable).
Old Dec 4, 2020 | 08:09 AM
2012 CLS63
Thumbs up
FREE TWO-YEAR
TIRE ROAD HAZARD
PROTECTION
Seems fair, similar to DT. You are the consumer, so I say go with what you're comfortable with GL to ya!
