DIY Panoramic Sunroof Clip Repair in Place
Old Nov 25, 2021 | 12:39 PM
Ajcr619's Avatar
2015 s550
2015 s550 w222
Originally Posted by flyboyusa
Hi everyone, the original set that I printed lasted about 3 months and now one has broken. I'm re-printing out of a stronger material that I'm hoping will last longer. I'm going to install and trial on my C400.
If I'm able to print some extras, I'll send out to whomever can test them for me.
I'll re-post once I have more printed.
how can I order some from you ? My passenger front side broken ! Need your help please.
Old Nov 26, 2021 | 11:25 AM
Balalb7's Avatar
c220d Premium Plus
Bro this is the exact same issue I have rn, I have ordered some clips brackets whatever you want to call them, from Ebay and I need help trying put them in.
Old Nov 26, 2021 | 11:39 AM
Ajcr619's Avatar
2015 s550
Clips
can you send the link where you bought them from please.
Old Dec 21, 2021 | 09:35 AM
flyboyusa's Avatar
C400
Message me your details and I'll get a set mailed out - they're $10 to cover my shipping - Venmo me @davet797
Old Dec 24, 2021 | 04:04 PM
C3004matidriver's Avatar
2015 C3004matic
I would love to try out a set, both of my front ones broke and I don't want to pull my headliner out. I sent you a private message if you have an extra set for sale.
Old Jan 8, 2022 | 12:44 PM
Ajcr619's Avatar
2015 s550
Clips
I'm going to hold off sharing the files, as I may want to sell them for a reasonable price if they continue to to work well.
The PLA seems to be holding up very well, no issues so far in the summer heat.
how can I order some for my 2015 s550 ?
Old Feb 22, 2022 | 12:10 PM
  #32
kiddprodigy's Avatar
c300
hey David, I’d like to purchase some clips for my 2015 c300. Are they still available?
Old Mar 13, 2022 | 05:19 PM
  #33
fordham511's Avatar
250CLK
replacement part
David - Brilliant - Why can't Mercedes come up with something similar. I have the roof apart and even purchased a roof from a junkyard.
Cannot figure out how to install the replacement slide grommet.
I would like to purchase four (4) if possible.
Thank-You
Ken
Old Mar 13, 2022 | 05:57 PM
  #34
flyboyusa's Avatar
C400
Thank-You
Ken
Venmo me $30 for all 4 clips along with your shipping address and I’ll get them sent out asap.
Old Mar 29, 2022 | 09:36 PM
  #35
Jake PL's Avatar
2014 S63
Clip link
Clip replacement
Old Mar 29, 2022 | 09:40 PM
  #36
flyboyusa's Avatar
C400
Originally Posted by Jake PL
These require complete removal of the roof liner and all trim inside the cabin to access and replace….very involved job
Old Mar 31, 2022 | 12:37 PM
  #37
Simontr512's Avatar
C250 amg line
Hi all....I recently started to do a DIY lube maintenance on the panoramic sunroof on my C400 and realized that one of the plastic v-shaped guide clips was broken.
After researching this problem, I realized that this is a pretty widespread issue with this OEM sunroof design and many people have reported a similar issue. This ultimately causes road noise and binding during opening/closing.
The published repair involves removing the entire headliner in the vehicle to gain access to the end of the guiderails in order to slide in the replacement clips (a lot of work).
I decided to design a repair-in-place clip to solve this issue. I printed them on my 3D printer out of PLA and installed on my car and it has been in service for about 2 months now without any issue. They are working amazingly well!
The clips will install on the guiderail, then the sunroof yoke will slip down into the grooves, then the retainer inserts will get a dab of superglue and be pressed into place to lock it all in place. Allow the glue to cure for 4 hours before using sunroof.
I was a bit leery that super glue would have enough "guts" to hold up....but it turns out the super glue is actually stronger than the PLA plastic.
Attached are a few pics showing the design.
I'm looking for anyone else who has the broken clip issue and would like to try out my clips? I want some additional feedback on how well they'll hold up with use.
Anyone?
are these available for purchase?
Old Mar 31, 2022 | 01:14 PM
  #38
flyboyusa's Avatar
C400
Yes, they are $30 per pair (per side) - you can Venmo me @davet797 and include your shipping address
Old Apr 1, 2022 | 06:56 AM
  #39
Simontr512's Avatar
C250 amg line
Anyone?
can these be shipped to the UK?
Old Apr 1, 2022 | 11:12 PM
  #40
2015 C3004matic
I purchased a set of these from @flyboyusa three months ago and he mailed them out promptly. I finally installed them a couple of days ago and they work like a charm so far. I replaced the passenger side first, and screwed up when two of the inserts popped off back into the track out of sight. So I had to make two more of those out of an aftermarket set I got off of eBay. I cut a little block of wood 3/8" wide to put in the track to hold the guides in place as I pushed the roof bracket down. It was easier to put the inserts about halfway into the slot and squirt a little superglue on them before I pushed them into place with a long screwdriver. I am amazed at how strong CA glue is. These have worked great so far, I wouldn't mind getting a spare set just in case. My only suggestion would be to design these a little beefier than MB did.
The first group on the left is the original guides that broke. The second set in the middle is an aftermarket set made in Turkey, they look less strong. The set on the right is flyboyusa's design.
The piece of wood I cut to keep everything in place. The inserts are halfway in place and ready for little bit of glue before I pushed them down where they go. The yellow dust everywhere is from the 4000 count pollen dust in Georgia.
Old Apr 2, 2022 | 06:14 AM
  #41
flyboyusa's Avatar
C400
Great to hear! It’s nice having a working sunroof for this coming up summer
Old May 13, 2022 | 01:25 PM
  #42
John WB's Avatar
Maybach S600
@flyboyusa I need a pair as well. I can Venmo you now. Email is barakatwill@gmail.com.
Old May 13, 2022 | 01:53 PM
  #43
John WB's Avatar
Maybach S600
@flyboyusa Venmo sent. I dont know where to send you my shipping info. Plz email me barakatwill@gmail.com
Old May 14, 2022 | 02:35 PM
  #44
petergaultney's Avatar
2015 GLA250
I may end up in the market for these as well. Checking to see if replacement will be covered by my extended warranty. Sunroof just broke this morning. Not too impressed with Mercedes' choice to use plastic here.
Old May 15, 2022 | 05:05 PM
  #45
theryanwoods's Avatar
CLA 250
I NEED THESE!
Anyone?
How can I get in contact with you to order these? I’d love to try out a pair as I really need a quick fix for mine.
you can email me @ R.Woods@kw.com
Old May 23, 2022 | 04:14 PM
  #46
Aa007's Avatar
S550
I am very interested. How can I order the parts from you?
Thank you.
Old May 24, 2022 | 06:09 AM
  #47
Adeel16's Avatar
Mercedes C220
Hi
I also require these clips. My left and right have broken. Please send me a listing where I can buy please.
TIA
Old May 26, 2022 | 05:50 AM
  #48
Adeel16's Avatar
Mercedes C220
Clips
I am interested in these clips. Mine seem to have broken from both sides. You able to email me at hu5s41n@hotmail.co.uk
Adeel
Old May 27, 2022 | 02:40 PM
  #49
foreigngarage's Avatar
Mercedes CLA45, Mercedes S63
Hey David,
How do I go about ordering these clips? Located in Indiana as well.
Old May 27, 2022 | 03:24 PM
  #50
cidtek's Avatar
C300 4Matic Tenorite Grey
Originally Posted by foreigngarage
Hey David,
It's been answered many times in this thread.
