DIY Panoramic Sunroof Clip Repair in Place
Old Sep 16, 2024 | 10:29 AM
  #151
sonofatuck's Avatar
Please hit me up about the clips. I can’t send you a message for some reason
Pls shoot me an email at ntucker99@outlook.com if you’re still manufacturing those clips. I’m in dire need of a set 😭
Old Sep 27, 2024 | 11:37 PM
  #152
95-Supra's Avatar
W205 C300
Just got them delivered recently from flyboy after I sent $60 for a set via venmo. Don't hesitate.
Old Sep 30, 2024 | 04:01 PM
  #153
Zg1815's Avatar
Clips
Hello , here I am in 2024 wondering if you still have the clips for sale.
Old Oct 11, 2024 | 06:01 AM
  #154
mrmef's Avatar
C250 CDI S204 4Matic
Unhappy
My sunroof was not closing properly so I followed a video to force close it and I am not sure how to open it again to do the replacement. Any suggestion will be really appreciated!
Old Nov 30, 2024 | 03:03 PM
  #155
axelwphoto's Avatar
2016 C63 Sedan (W205)
Lightbulb I just made these and published to my personal website. Easy to order
Looking at all the threads & forums, I've designed and produced a drop in fix for similar issues that people are describing. Took the best of all the solutions, and made it easier to order IMO. Dropping this for help!
Let me know how it works and how I could improve it!
Works great so far in my test-vehicle; my personal w205 C63!
Cheers everyone!
https://ttartcollection.com/collecti...cls-class-c257
- Axel / Axel W Photo / Ttart Collection
Old Dec 1, 2024 | 02:29 PM
  #156
Aa007's Avatar
S550
Cheers everyone!
Do you have a video illustrating the installation process for your clips?
Old Dec 11, 2024 | 11:58 AM
  #157
BryC220d's Avatar
Hi guys,
My C220d 2016 makes an awful like "rattle / creek" when I'm driving down the road, when I open it ever so slightly and continue driving it goes silent, does any one know if these clips will fix it
@flyboyusa any thoughts buddy?
Old Dec 11, 2024 | 06:09 PM
  #158
Greg52's Avatar
W205 C250
Originally Posted by BryC220d
Hi guys,
mine was like that from new, took MB many attempts under warranty to fix it. After that I have never opened it again . So in my case the clips were intact, it’s a very fragile assembly and I wish my car didn’t have one
Old Dec 16, 2024 | 05:29 PM
  #159
AnimaChristi's Avatar
2016 GLC 300
Howdy,
Hoping you still have some clips to sell. Thank you.
Old Dec 16, 2024 | 06:19 PM
  #160
flyboyusa's Avatar
C400
Originally Posted by AnimaChrisit
Howdy,
yes I do
Old Feb 1, 2025 | 02:38 AM
  #161
pabz707's Avatar
C450 AMG
I just got my set of clips from the French guy. The problem is that only a corner of my sunroof opens and then gets stuck so I can’t get it fully open to install the clips. Has anyone been able to somehow get the roof to slide open with this same issue? Trying to avoid dropping the headliner… 2016 C450
Old Feb 1, 2025 | 09:01 AM
  #162
Jetfuture's Avatar
2016 GLC300
Here is what I wrote in May 2023:
"I live in the United States and bought the one from France. They were shipped from France in about 3 days. I received the part about 9 days after they were shipped. I installed it this morning and it worked! You will likely need to adjust the bracket/glass a bit lower on that side. I just loosened the two Torx T25 bolts, moved the glass down about 2mm or so and retightened. Then I closed the sunroof and it fit nearly perfect. The Mercedes spec is that the sunroof sits from between 0 to 2mm above the adjacent fixed glass. Use a credit card the compare the sunroof glass to the fixed piece of glass when the sunroof is closed.
Can't speak to how long the part or sunroof will work. But it did open and close the 4 times I needed it to. It is now in the closed position and I will never use it again.
Thank you to the developer in France who 3D printed this piece. Saved me between $2,000 and $3,500. It is a genius design."
Somehow, you have to separate the glass from those front slider mounts, which is held on with the aforementioned T25 bolts. I believe I undid then bolts on both front sides of the sunroof, yet only replaced one of the sides (which was broken). I was kind of thinking I should have ordered 2 of those clips so I had a spare if the other side ever broke. But I don't use the sunroof glass anymore after I got it all back together and adjusted.
Old Feb 7, 2025 | 11:54 AM
  #163
caseybueno's Avatar
2018 C43 Sedan
Cheers everyone!
How do your sliders lock in? Is there a pin that slides in like that other design?
Old Feb 11, 2025 | 11:47 PM
  #164
notmbfan's Avatar
Unfortunately, looks like we can’t order from your site
I get an error saying you can’t ship to my address.
Cheers everyone!
Old May 3, 2025 | 08:32 PM
  #165
pabz707's Avatar
C450 AMG
Did you drop the headliner? I have the issue where only a corner of the sunroof pops open. It won’t physically slide back and fully open so I don’t have access to the clips to make the repair. I’ve tried gently prying it open and pushing up from underneath but still can’t get it to slide back and open fully.
Old May 3, 2025 | 09:24 PM
  #166
Jetfuture's Avatar
2016 GLC300
I did not drop the headliner, as my motors and rails were working just fine. I was able to open the sunroof a foot and access the front clip area just fine. Sounds like perhaps you have a problem with the motor, the rails, or the rear attachment (in addition to a broken clip). Sorry to hear about your predicament, and wish you luck in finding a solution that works for you.
Old May 6, 2025 | 07:21 PM
  #167
A13X37's Avatar
2016 GLA250 4MATIC
Still selling? Just want to confirm before i Venmo you.
Old Jul 22, 2025 | 07:20 PM
  #168
BDT8600's Avatar
c400
I NEED CLIPS
can you please email me at trevordanderson1@gmail.com so I can get the clips?
Old Aug 4, 2025 | 07:44 PM
  #169
sambam2006's Avatar
GLC Coupe, S63L W222
Hi FlyboyUSA, I bought your clips a while ago and finally fitted to my car but one side of the sunroof doesn't sit flush and sticks out, I can hear wind noise, other side is OEM and not changed, that side sits fine. Please advise?
Old Aug 10, 2025 | 08:06 AM
  #170
shabbauk's Avatar
s4
Hi, is is thread still alive?
If I understand it correctly, there are 2 clips per side. Seems one clip is broken on mine, and I've ordered the french ebay fix, does anyone know if I need to try and remove the other clip before installing the fix? If so how easy is that to do? I;m not quite clear, any help would be great.
Old Sep 9, 2025 | 05:39 AM
  #171
Maher Lababidi's Avatar
2015 C63s, 2005 E55
broken clip on 2015 c63s looking for updated clips
Originally Posted by flyboyusa
yes I do
flyboyusa, ran into a broken clip on my 2015 c63s and came across this thread. gotta say, big props for putting the time into making these clips, looks like you’ve helped a ton of people dodge an expensive dealer fix. just wondering if you’re still offering the updated ones.. i’d be down to grab a set if you’ve got some available. i appreciate the work you put in on this!
Old Sep 9, 2025 | 07:11 AM
  #172
flyboyusa's Avatar
C400
Hi, yes I still have some. $60 for full set, Venmo @davet797 and include your shipping address in the Venmo transaction
Old Sep 9, 2025 | 07:23 AM
  #173
2015 C63s, 2005 E55
will do thanks for confirming just to be sure when you say full set is that 4 clips or 2 i only really need one but if it comes as a pair thats fine ill grab them 🤙
Old Sep 9, 2025 | 07:31 AM
  #174
flyboyusa's Avatar
C400
I sell 4 clips as a set to replace both sides
Old Sep 10, 2025 | 02:22 PM
  #175
Tommytrojan's Avatar
24G63,21GT634DR, 17C63s, 08GL450
Do you have installation instructions? I have same problem too.
