W205 C Class Piston Crack M260/M264 (2019+)
Where are E300 M274 engines assembled?
The GLC300 also uses the M274 engine.
The M264 shares many components with the M274, notably the crankshaft and connecting rods. However, the piston part number is new for M264. Whether it is a modification of the previous M274 design or a clean sheet new piston design, is unknown.
- cracked piston
- failed cylinder head
- broken connecting rod
- or others
Please keep us updated and if you can, please post a copy of the service quote/invoice with your personal information removed.
Nowadays, Mercedes-Benz has eliminated
the M264 engine in only three years. The
Mercedes-Benz C-class (parameters | pictures),
as the representative model of the M264 engine,
according to the vehicle quality network data,
the main problems of the C-class are
concentrated on the engine motor failure and
the engine failure light., The engine shakes and
cannot start.
https://www.classaction.org/news/mer...ng-m274-engine
I am a former Ford engineer and MIT mechanical engineering graduate (Masters and Bachelors). I have also been a mechanic for 39 years. I have engaged the law firm and will likely end up being the engineering and mechanical expert on this case.
I encourage you to get registered for the suit if you have suffered a loss. Do this before you dispose of the vehicle.
- Jason
- Jason
