LOSING ALL POWER ON FREEWAY - "Collision Inoperative" RECALL ASAP
I have a c300 4matic 2015 with 91K miles on it. With the exact same issues happening with the "Collision Prevention Assist Plus Inoperative" along with the cruise control inoperable when this message pops up and the traction control symbol is illumined yellow. I then lose all power to the vehicle, it enters a "limp mode" if you call it that. Driving 75 down a highway the car will randomly activate this warning and you lose all control to accelerate. You have to quickly pull over and restart the car, the message then disappears and all is back to normal. *THIS has only started happening once a new battery was installed by MB dealer last week, the day after driving down a freeway and has happened 5-6 times over 7 days. Could you imagine having a family in the car and losing all power in the center of a freeway?
Immediately called MB service advisor (when it first happened) who told me to wash the car as it's winter here in Minnesota. Which seemed valid as sensors can do crazy stuff when dirty... Did that, the next time I started the car drove it for 30 seconds, same issue. Inoperative warnings come up and lose the power to accelerate. There is NO check engine light on.
So I dropped it off at Mercedes, thinking they installed the battery wrong and needs a software update. They came back with many fault codes, however they singled out the Thermostat? P059700. HERE is the KICKER - The tech then sent a $1,000 credit from Mercedes to fix this??! Seems quite odd to me, they didn't give me credit for he $1,600 crankcase value I replaced last summer.. Anyhow They want over 2K to fix the Thermostat, claiming low temperature of cooling system is throwing off codes and reason it's throwing the collision assist inoperative warning and limp mode. BUT with no check engine light? I've read all of the forums containing to this issue and not one has related this to the thermostat..
A week ago the battery was changed and a service tech did an inspection. They found all levels normal and the car in "great" condition.... Now not even a week later they did another inspection today and found my oil to be overfilled, the wanted a b service, wipes replaced and this thermostat to correct the issue??? I have a hard time believing them that the thermostat could cause collision and cruse control warnings..
Any insight would be great. What should I do? Similar issues - sure looks like it!
I have videos to post also, would that happen explain this issue?
