How To Install LED Turbo air vents
How To Install LED Turbine Air Vents
Any of you guys can share with me his experience in installing these LED Turbo air vents. Or maybe an installation guide for these vents. I am mostly interested on where to connect the end cables. My car has factory 3 colour ambient light.
Cilo C Class (05-29-2021)
Ok, you'll have to connect it to the door panel module, check this video :
https://youtu.be/L27sEMZQ2ho
Sorry it's not in English, but you can see the steps.
https://www.incarpassion.com/instruc...-ambient-light/
thanks. I tought connection will be to the fuse panel found on the driver side. Please have a look at the bellow. The steps are different then the video. Its just these cable connection that i didnt understand. It looks like this is not a DIY job:
It will work yes, but not synced.
If you look at the video, there's a connection that goes from the door panel module to the air vent, if you don't have it, check with the supplier you purchased from.
Well, if you connect it to the fuse box, how will it sync with the other lights ?
then that's easy you connect the led light to centre console is the blue plug I guess..you led air vents will come with bridge connection where you remove the oem plug and connect to led airvents and other end from the bridge goes back to the plug where the oem came.off from
The seller instructions were terrible and i think there are a few different types of vents, all with slightly different installations. I mostly used Flexxalexander's Youtube video to understand how to remove the air vents and the centre console. The kit I received had all LED cables from each vent merge into one cable. I had to actually remove the connector pins from this cable (brown, yellow & blue) and insert these pins into the connectors that would usually plug into the socket which gives the centre console LEDs power. Sorry it's really hard to explain over text but if you get stuck just send me a reply with photos and i'll guide you
Here's some shots in light and in dark. The light is actually in the centre of the vent, but it reflects nicely around the entire vent. One issue that I have though is when i'm looking at my side mirrors in the dark, the vent restricts my vision a fair bit. Could also be because my windows are tinted as well, but I typically roll down my driver side window when I can't see properly.
Corvette Grand Sport, Mercedes C43 sedan, Jeep Grand Cherokee
Does anyone know where the ambient can bus connection would be for a 2021 with 64 color ambient light. Or can I just hijack the connection to the center console LEDs? I haven't been able to get a really straight answer on this and don't want to rip up my interior looking for a connection point
I was only sent one of this particular relay all of the other door relays are different they are 3.0.
I figured out how to wire the speaker covers and the tweeters. I’m just not positive where to power up the Seven vents.
