Double Clicking on Remote Control Seems to Save Main Battery Power
Old Aug 8, 2021 | 04:46 AM
Andy74's Avatar
W205 2015
Hi guys, I used to close my car by clicking once on the remote control. When i come back to the car say like after 2 days i unlock the car and a stop vehicle turn engine on message pops up on my dashboard basically warning me that the battery power is low. Lately I started clicking twice when closing the car as I heard it shuts down all systems in the car mainly the push start stop function. I noticed that the above message never came back even if leave the car for 3 days.
Old Aug 8, 2021 | 11:33 AM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
It’s in my manual. It shuts down the keyless entry, etc. I would suggest you think about a new battery.
Old Aug 9, 2021 | 09:14 AM
Andy74's Avatar
W205 2015
I was thinking to change my battery but the stop vehicle turn engine on message disappeared when i started double clicking on the Remote Control.
Old Aug 10, 2021 | 05:14 PM
np6345's Avatar
'19 E300 w/ activated Multibeam
Definitely something fishy with the battery, i would get it checked for free at your nearest autozone. I can go for weeks without turning on my car (2015 c300) and it always starts right up instantly, never seen the low battery power message yet.
Old Aug 10, 2021 | 05:32 PM
Andy74's Avatar
W205 2015
How come the message disappeared when i started double clicking on the remote. I never saw it again.
Old Aug 11, 2021 | 04:10 PM
LaciCLK320's Avatar
C300, CLK320(sold)
Your keyless entry is draining your battery! As others mentioned it double clicking disables it.
Old Aug 11, 2021 | 06:50 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
That doesn't mean your battery is not sitting on the weaker end atm
Old Aug 11, 2021 | 09:37 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
I believe double clicking turns off the fob, thereby saving the fob battery. It doesn’t turn anything in the car off.
Old Aug 11, 2021 | 11:20 PM
ItalianJoe1's Avatar
2003 CL 600
Yes, it just turns the key off, but if the key is normally alive and within some sort of range the car can see, like by your door and the car is outside in the driveway, it could be waking the car up from time to time. Turning the key off, once the car goes fully to sleep after 15-20min, it won't wake up until an active remote signal hits it or the door handles are activated, it won't get the passive ping from the key and start running networks or anything.
But yes, change your battery if it's that weak.
Old Aug 12, 2021 | 12:55 PM
stockbmw's Avatar
2018 C43
Regardless of car being awake or not, the subtle whirl from your comand shouldn't drain your battery next day.
What is your commuting distance each day? How many times do you drive per week? If you are working from home, best to plug your car to a battery maintainer instead worrying about key fob that never gets seen from my pocket.
