Door panel TRIM removal
Any suggestions and tips would be really really appreciated Kush bhai 😉
The entire trim should pop off so you'll technically have 2 pieces. 1: the actual door panel and 2: the trim that houses the speaker. Once the trim is disconnected from the door panel, you should be able to freely remove the speaker with all wires intact. I've never taken the speaker off so this is just my thought.
LMFAO bhai bhai 😉
I saved this for a speaker upgrade at some point
LMFAO bhai bhai 😉
Yup! I was going to send you the same video. I used Flexx's video to do my ambient lighting which shows the removal process of the door trim. It also shows the process of what to break off and where to Hot Glue. Hope the video helps!
