1st gear start?
I know that driving in sport mode makes it start in 1st, however, driving all the time in sport mode is not an option for me.
If I manually shift down to 1st at a standstill and switch back to auto mode (by pressing down the shift lever while still standing) then the transmission automatically shifts back into 2nd. So, yes, I've tried that and it doesn't solve my problem.
I was also thinking of some kind of mechanism that activates the kick down switch under the throttle without actually having to depress the pedal.
Any other suggestions?
Once the TCU is reset the car reportedly learns from the driving style of the next 15 minutes. I wanted a more sporty behaviour after having driven the car gently from new to run it in. I reset mine at a motorway service station then selected Sport mode and drove it hard. Your preferences and mileage may vary!
I know how to perform a TCU reset, but that won't change the fact that the 9G transmission starts in 2nd gear in comfort mode.
I can't stand that mine starts in 2nd. I also couldn't stand the digital instrument cluster, so I swapped it out with an analog one. I guess I'm somewhat backwards.
You need a TCU tune to change any transmission mappings, but as far as I know there are no TCU tunes for the 9-speed yet. Some tuners have TCU tunes now for the 7-speed AMG MCT transmission it seems, but nothing for the 9-speed MCT either. Haven't heard of TCU tunes for the regular MBs, though. Basically if you want a more responsive car off the line, you need to go AMG, or use the Sport modes, as you've already discovered, to get more pep, or manually shift yourself.
C43 in other hand decides that for you from it's genius ecu and when you feather your gas on S+, car thinks you are going but you are not, combine with your gas foot being indecisive, it performs the motion.
