W205 - Intermitent Start Fault and Re-Start From Start/Stop
Think i have an interesting one so any thoughts would be v much appreciated!
My 2015 C class W205 250d Bluetec has had an intermitent fault whereby it sometimes won't start. On the push of the button, the ignition lights come on but nothing happens. The engine doesn't crank at all. The engine light stays on, but disappears within a few seconds. Normally, a second attempt is required to start it and when it does, it runs fine. I sometimes have to push the button a couple of times which i understand cycles through ignition sequence and then the car starts fine.
I also have the same intermitent fault on the start/ stop. The light goes green, the engine stops, but doesn't always restart when i go to accelerate.
I've tried using my spare key and even putting the key into the ignition, but the problem persists. I had the main battery replaced 18months ago (Varta F21) and have charged it using a smart charger. Voltage once surface charge has dissipated is about 12.3v. On engine startup voltage drops to 8.5v-8.7v at a minimum. As soon as the engine has fired the voltage goes up to 14.5-14.6v.
I have checked the fuses and done a basic check on the relay on the starter and couldn't see any issue. I checked the resistance which was 82ohms which i have read is outside of tolerance on another forum so i have ordered a new relay just in case.
I do not have any fault codes using iCarsoft MB v2.0 with the latest firmware. Many people complain about the Aux battery (or capacitor) but i do not have a malfunction warning and the start/stop light goes green which makes me think the issue is on the starter circuit rather than the stop/start circuit.
Has anyone got any ideas what the problem could be before i have to take it into a stealership?
Many thanks
What's next, the starter failure?
I read somewhere there is a relay or solenoid as part of the stop/start by the wiper motor, anyone got any ideas about this?
I've noticed that when it fails to start there is a click coming from the engine (assuming this is the starter engaging) but nothing happens. I can only just see the starter motor but cant get to it. The ignition lights go off and the engine light remains on but goes off after a little while. I've tried to see if anything is apparent on my iCarsoft MB v2 tool but cant see anything.
Any other ideas would be greatly appreciated, but just to be clear the issue occurs upon starting the car from the ignition and upon restarting from an eco stop/start. Thanks
Go get your battery tested by another store like AutoZone for free, you should get a print out saying your battery is defective, use this to get new battery since this one is still under warranty.
And how many days is your car being driven in a week?
With the drop in voltage on starting, could this stop the car from cranking period? Not sure how much drop in voltage there is when the car fails to start given the starter isn't drawing. The bit thats odd to me is the fact that normally on the second attempt the car starts straight away, no hesitation.
Easiest solution is go buy 12v battery with good return policy like Costco and use it for a week to rule out the battery. Be sure to test this while cranking to see if it drops to 8v or hovers at 12v.
Any other suggestions?
https://mbworld.org/forums/c-class-w...-stalling.html
It isn’t a simple battery issue. New battery and auxiliary battery / voltage converter didn’t fix it.
Also you need xentry to get the all the codes since those code readers don’t pick up everything. I have P1CE200 which is basically Eco start / stop detected low engine speed
I have seen 10.7~10.8V when cranking, but 8.x is not normal even if the battery passed the test. Or the start motor drains power abnormally. Check the start motor relay…. if you couldn’t find the cause.
Many thanks
