C220d w205 door lock actuator
I'm having an issue with my 2014 c220d Blutec w205.
So basically my drivers door does not lock properly. I press the fob, everything works as it should but when I pull the drivers door handle the door opens. Sometimes it doesn't open, but if I pull a second time it does. Or if I pull it hard enough the first time it will open. I only found this fault as i caught someone in my car in the middle of the night stealing stuff and i know i locked it. I'm thinking it's the door actuator but can't find much info online. Is this a common fault?
Thanks, Sean
And no it wasn't him, he opens the door quite gentle, like it wasn't locked. After he rummaged around he went to the back door which was locked and just left.
Once I took care of the loose cables and re-attached the rod to the inside handle it fixed that issue.
