Trunk/boot soft-close repair guide
Old Apr 2, 2022 | 05:02 PM
Phat_J's Avatar
2015 C400 Sedan
Cool Trunk/boot soft-close repair guide
Hey all,
So I had an issue with the soft-close feature not functioning on my 2015 C400, I fixed it, and decided to make a guide for it in hopes of helping others. There's a pdf version of my guide attached to this post too.
The issue. Power assist trunk / boot does not fully shut, leaving this unsightly gap:
Thanks to this post for the picture:
https://mbworld.org/forums/c-class-w...t-problem.html
The likely culprit. This motor is engaged when the trunk/boot lid has finished closing, and pulls it fully shut:
Here is how to diagnose and replace that motor.
This guide is for the W205, but many other models use this same motor
(https://www.autohausaz.com/pn/MB-2047500060)
Tools needed
- Replacement motor (I found mine on ebay, part number A 204 750 0060 / A2047500060)
- Trim removal tool
- Torx screwdriver
- Needlenose pliers
- Flashlight
- Multimeter and some spare wire (optional)
1. Remove lower edge of trunk
a) Remove plastic rivets
I found this to be the most difficult part. I pried the rivet a bit with the trim removal tool, once they were partially extracted, I used needlenose pliers to grab them and pull them out.
b) Once the 2 black rivets are out, pull up hard on the trunk piece and it will pop out. There are 4 white rivets that hold it down.
Now you can see the mechanism that gets pulled by this wire encased in foam. The wire leads to the failed component that we'll be replacing.
2. Gain access to behind the trunk lining
a) Remove the tie-down latch with torx screwdriver (plastic top easily pops off)
b) Remove plastic hanger/fastener
c) Pull back on trim to reveal motor unit. You may have to use a trim removal tool to pry it free.
d) The motor is contained in a plastic and foam enclosure held on by an orange rivet
e) The enclosure can slide to detach from the orange rivet. I also detached the power cable.
3. Diagnosing, testing for power:
At first I wasn't sure if the motor was faulty, or if it wasn't getting power to do its job. Or, the cable may have become dislodged over time. Skip to step 4 if you want to just replace the unit without testing it.
a) The motor unit is in a foam enclosure held on by an orange rivet, you should be able to pull up on the unit and it will release from the orange rivet. Then you can pry out the orange rivet with a trim removal tool.
b) Disconnect the power cable.
c) Fold down the right rear seat.
d) I’ll be running some wire from the power cable to my multimeter, so I can read the multimeter from the back seat while the trunk closes. I connected some wire as shown to the trunk motor’s power source, and ran it to my multimeter.
e) As the trunk closes, watch for the multimeter to show 12 volts. This means the soft-close motor is getting power to perform the soft-close. Now we know it must be a faulty motor, assuming the cable running to the latch is attached properly.
https://streamable.com/4vnlvn
4. Remove and replace the faulty motor.
The “ball bearing” end of the wire detaches easily from the unit, along with the blue piece holding it in place
b) Attach the cable to the new motor (the cable should wrap around, and the blue piece should snap into place as shown)
c) Connect the power cable and seat the motor into the plastic and foam enclosure
d) Pry the orange rivet out from the frame of the car, attach it to the motor enclosure, then push the motor unit with the rivet back into the frame. My apologies for not taking a pic with the rivet seated in the motor casing, but hopefully it’s intuitive. Red arrow shows where the rivet should go.
5. Test it
a) Make sure none of the trim you removed is in the pathway of the trunk closing
b) Close the power trunk and see if it fully soft-closes. Please excuse the dirty car
https://streamable.com/mx5i96
6. Re-install trunk lining
a) Make sure the lining goes fully under the rubber trunk trim
b) Re-attach the hanging clip, the tie-down latch, and plastic covering
c) Re-attach lower edge of trunk, make sure all 4 rivets click back into place
d) Make sure the rubber trim is over the edge of this trunk piece. I used a trim removal tool to run along this edge.
e) Re-attach the 2 plastic rivets into the trunk piece
Done!
Old Jul 25, 2022 | 08:48 AM
SorinMB's Avatar
c250
Dunno if its bad luck but i got mine off some spare parts, tested and worked, 2h later doesnt work
I need a new part
Old Feb 17, 2024 | 08:08 AM
Penguin123's Avatar
C200
Thank you. Thank you. Thank you.
With your impeccable instructions, I was able to fix this effortlessly. You shine like a star and embody true kindness, sir, for graciously taking the time to provide such detailed guidance. I am sincerely grateful to you, thank you from the bottom of my heart!
Old Mar 8, 2024 | 01:04 PM
Phat_J's Avatar
2015 C400 Sedan
You're very welcome! Glad I could help
Old Mar 17, 2024 | 01:11 PM
rxm00's Avatar
Mercedes C-Class C220d 2016 W205
Thank you for providing this tutorial.
My boot has also recently been experiencing this issue with it not being closed entirely. I do not have a multi meter to test but I’m just going to guess it’s very likely to be the same culprit.
I have just had a visual look my motor and I can see it looks like the following image you provided, and doesn’t wrap around:
What mine looks like currently
Now, was it like this for you? The original part not being wrapped round like the following image?:
Should it look like this and the cable be wrapped around?
I have found a second-hand motor like pictured above with the cable looking like it will be able to be wrapped around:
So, do you know if the one above will likely work just by looking visually? I’m trying to understand whether the fact that when I look at my current motor the cable doesn’t wrap around, is this the problem? Baring in mind my boot is open so I don’t suppose that’s why it isn’t wrapped when I have had a look, or whether the motor just doesn’t work. If you can advise it will be much appreciated.
Originally Posted by Phat_J
Hey all,
Tools needed
- Trim removal tool
- Torx screwdriver
- Needlenose pliers
- Flashlight
5. Test it
Done!
Old Mar 18, 2024 | 12:41 AM
Phat_J's Avatar
2015 C400 Sedan
It's hard to say if it's not functioning from just seeing the picture. Can you turn the motor at all by hand, and put it into the position like my picture?
Old Mar 24, 2024 | 12:20 PM
rxm00's Avatar
It’s hard to turn by hand but I managed to turn it so it is like the one in your picture where the cable wraps around, however, when I close the boot doesn’t latch on at all and therefore doesn’t close. With every close/open cycle the motor goes lower and lower back to the original position as shown in my first image. Does this show that the motor is knackered and not working? As my guess is that it doesn’t seem to engage and wrap the cable back round when the boot is fully closed which i guess would be the motor ‘vacumming’ the boot closed.
What would you say to this? I might just bite the bullet and purchase a second-hand working motor? Thanks in advance
Old Mar 27, 2024 | 01:27 PM
Phat_J's Avatar
2015 C400 Sedan
I would say just order a replacement part instead of messing around with this.
Old Apr 2, 2024 | 03:17 PM
rxm00's Avatar
Hi @Phat_J . I just received my second hand motor with same part number and attempted to fit it. I followed all steps and wrapped the cable round, clipped it in place and connected the wires back up and when i close the boot this motor does not engage at all and does nothing. The cable being wrapped round is the motor already in the closed position where it ‘vacuums’ the boot shut and therefore when i press the close button for the boot it doesn’t close as the latch is too far down. But the motor just doesn’t move at all for it to be in the open position. If I push the boot down once it does lock all the way and the panel gap is perfect as it would be if it ‘vacuums’ shut but when i open the boot again the motor just doesn’t engage to release the lock on the cable upwards.. any ideas?
Old May 1, 2024 | 08:48 PM
Vins's Avatar
Mercedes C250 W205
This is god
This is absolutely fantastic person guys! I must send my appreciate from Australia. You make this job so easy. Thank you so much
Old Sep 18, 2024 | 12:02 PM
WriterandPhotog's Avatar
2022 MB C 300 Coupe
Thank you for taking the time to put this guide together. I was at my Mercedes dealer a couple of days ago for a B service. The service writer is a former tech, so I quizzed him about his thoughts on this being the problem with my car.....the trunk has the same space/gap as in your initial picture. He thought it was the striker plate and after looking at mine out in the service area, said he thought it looked bent. I just removed the outside cover and used a vice grip to "straighten" it, but I still believe that my problem is the pull-down motor, even though this service guy didn't think so. When I pull on the ball at the end of the cable, it has about an inch of slack........would that be normal? Would it only be under tension when the trunk is closed? Also, it seems to be touching the spring, while in your pictures (or those you link to), it appears that the cable should be about a half-inch from the spring. Again, maybe this is just because it is only under tension when the trunk is closed. Any thoughts? I went to the parts department when I was at the dealer, and of course, they did not have the $70 pull-down unit in stock, but they said I probably needed the cable/striker plate and that was about $450. How can that be more than a motor?
Old Oct 9, 2024 | 05:08 AM
2022 MB C 300 Coupe
Update.........I removed the panels from the inside of the trunk and accessed the pull-down motor and removed it from the plastic case and insulation. To my surprise, the ball and cable on the motor end were disconnected. Had already run a test with my multimeter to confirm that motor was receiving power. Reconnected the cable to the motor end and all is good now.
Old Jul 21, 2025 | 04:19 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
This piece is tough. Did you start at the top ends and wedge a plastic pry tool underneath?
Old Aug 1, 2025 | 04:09 PM
zildjian11's Avatar
2005 CL500
Thank you for this very detailed guide! It allowed me to repair the trunk pulldown mechanism on a 2019 C300 in about 20 mins. On mine the cable had simply disconnected from the motor, so I did not need any parts. Just reattached and all fixed!
Old Sep 18, 2025 | 08:35 AM
Dodgers's Avatar
w205
Many thanks for the detailed guide, I did the power checks and then reconnected the motor and viewed with the rear seat down and could see it wasnt turning all the way round, replacement motor from Amazon A2047500060 (it was actually listed for Tesla) slotted in and worked perfectly.
