C400: Changed my Spark plugs today... Some thoughts
I took a fair bit of video of the various "stages" of the repair, which I plan to put on YT later this weekend, if anybody's interested.
A couple of random thoughts. While doing my research prior to starting this job, I ran across a fair few threads talking about "Spark Plug Indexing." I had never heard of this before, and I was a little worried that it might be a complicating factor of what is, otherwise, a pretty straightforward operation.
After a bit of thought, I decided to ignore it, and simply ensure the plugs were properly threaded and torque'd. Evidently I chose correctly because the car started right up, purred nicely and pulled hard on a shakedown drive.
Last thing, I used anti-seize. I know NGK and MB don't endorse that practice, but I've been maintaining my own cars for 25 years, and I tend to stick with proven practices. So a VERY modest amount of copper based anti-seize was applied 3-4 threads away from the electrodes.
Oh, and here's the old plugs.
Driver side bank, far left plug is cylinder closest to front bumper.
Passenger side bank, far right plug is cylinder closest to front bumper.
The proper indexing is accomplished by a combination of the crush washer on the plug and applying the correct torque. That's it, that will set the electrode in the correct position.
You've used anti-seize on a steel fastener/plug in an aluminum block before? Just curious, I've never really dabbled into using anti-seize before... even though there have been times I wished I did!
[EDIT] it's not so much the Block material you have to worry about as it is the Head's material. Every motor I've owned since 1998 has had an aluminum cylinder head (even the 1982 Volvo 242 Turbo), and anti seize has never been an issue.
I have used anti-seize on every spark plug on every engine I've ever serviced. From a lowly 2.0L Ford Zetec, to the Audi 4.2L V8. I've had ZERO issues.
I advise against anti seize in a dry torque spec application. Not trying to persuade you otherwise, just indicating that I would avoid it.
The index is determined by a dry application tq spec. Adding anti-sieze will allow for additional plug turn past the ideal index location. This would in theory make for slightly less efficient burn, but i doubt you would notice.
Also stock interval is like 55k, but if you are going to push more boost and mods, most tuners recommend more frequent changes. There really isnt enough time or miles to have the plugs get oxidized and stuck in the block.
Ive done them on my C400 and the wifes ML (3.5L M276) twice. The 3.0 is a piece of cake, especially if you have aftermarket intake.
Unless you're using a torque wrench that is lab grade, +/-1.5nm is going to be inside your margin of error anyway.
My results so far seem to have borne out that we're obsessing over something that makes very little difference.
However, a few thousand miles on a car with no issues is no problem.
