Aftermarket Android Screens - Downsides
I got close to purchasing one recently (DMP Car Design) but I keep getting hung-up on not wanting to switch back and forth between Android and NTG.
An example of what I mean is; I need and use the temperature, A/C and fan speed bar at the bottom of the OEM screen a lot. Does anyone know if that bar still automatically pops-up while you are in Android?
For those that have done this upgrade, what are some of the things that are missing from the OEM screen that you have to switch to NTG for, or that bother you about the Android screen?
TIA!
Jay
I had the non-command stock system, so not missing much from the NTG. Only time I go back is for the radio, but I could probably get that on Android as well, just haven’t looked hard enough. Also, having Amazon music and Pandora at my fingertips helps!
I agree, it would be silly to remove the climate lower banner, but I can't see it on any of the descriptions, screenshots or videos I've watched so it was making me nervous it's not there.
My plan is to create a unique Google account for the car Android and using a 4G data only plan/SIM card.
Has anyone done this and does everything work as expected, Google nav, etc.? (except calling features of course, don't need that anyways)
Whilst the unit I had was at the end of my life with W205 a glorified CarPlay screen, I had a SIM card installed in it with which you didn't need to have the phone on you at all; Spotify, Google Maps, even the likes of Netflix etc. worked just fine.
If you do decide to go for it I'd suggest checking out https://play.google.com/store/apps/d...hl=en_GB&gl=US it makes the Android screen feel like an NTG5.5 unit.
Ooo, that interface app looks sweet. Thanks!
I'm getting closer to a decision to just do this. Maybe.
Are you talking about something like this, and connecting the Android screen to the factory COMAND headunit with RCA jacks instead of the default kit USB setup? https://www.ebay.com/itm/264389006609
Thank you!
Thank you!
The harness for COMAND actually has AUX already there, you just need to enable it with coding so I'm talking about something like https://www.aliexpress.com/item/1005003639367545.html
The best tip I can pass along is to use the COMAND AUX IN as your audio source by connecting the Android screen 3.5mm audio out male jack (single wire) to the AUX IN pigtail female jack coming out of the wiring harness terminal block connecting to the COMAND head unit.
You will need to activate AUX IN on your COMAND head unit in order to select AUX IN as your audio source (I used a OBD flash module I got on Ebay to activate mine).
This will eliminate the audio quality and audio delay issues that plague a lot of the USB audio connections.
Some more info:
https://mbworld.org/forums/c-class-w...ml#post8651079
https://mbworld.org/forums/c-class-w...cher-apps.html
can you give a little more explanation on this about the DAC?
many thanks
Order has been placed.
