Guatster
Old May 18, 2022 | 10:39 PM
Guatster's Avatar
2016 c300
Guatster
Hello everyone
I have a 2016 c300 with 100k miles . I bought 2yrs ago with 48k miles . Today a piston went out . spark plug was found broken and now compression on that cylinder is 15psi . Mechanic states a new or used engine is required. can any one please advise of other possible solutions .
Old May 19, 2022 | 06:45 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 forum...
Old May 20, 2022 | 11:34 AM
Keith66's Avatar
2018 AMG E43
Originally Posted by Guatster
Hello everyone
Hi Guatster,
Sorry to hear! Do you happen to know when the spark plugs were replaced? If they are the original plugs, this may have been a contributing factor to the failure. I'm curious, is this on #1 (the cylinder at the front of the engine)?
The next steps and options depend on if there is damage to the cylinder bore/wall and the extent of it. Also "a piston went out" could mean many things, do you know if it cracked, a hole blew through it, a chunk missing, ring blow-by, etc.? Everyone has their own path and choices, but if this happened to me and there was no scoring of the cylinder bore/wall, I would be working with an independent shop that specializes in Mercedes to have the one bad piston replaced.
