Exhaust Temperature sensor bank 1 sensor 1
Old Jul 11, 2022 | 05:39 AM
Sgb1's Avatar
C220 CDI
Hi Guys, I have a c220 cdi with a engine light up, diagnostics throw up a code saying P2080 suggesting that it's the exhaust temperature sensor bank 1 sensor 1, I've had a quick look and have brought a new sensor.
I'm curious to know as the sensor has a notch, is this just because its a metric thread or a reverse thread ?
as its the only sensor with a male insert.
Also with this sensor going does it reduce engine performance and how smooth the gearbox would function as they both seem to have gone awall after the light coming up.
Old May 6, 2023 | 07:50 AM
greed_95's Avatar
‘15 ML 350 Blue Tec
Hi, I am assuming you had this fixed? I have the same issue on my ML 350 BlueTec W166. And i noticed the same the transmission gear box was a bit jerky at times and the engine performance was in a limp mode(ish). After you had it replaced did these issues get rectified
