W205 Mechanical/Electronic Failures and Repairs Database
Scattered throughout this forum are many reports of failures (as with ALL mechanical machines), and when combined, form obvious trends like the Auxiliary Battery malfunction, #1 cylinder issues, pano roof issues, etc. I think we may find similar trends here if we all openly share our specific component failures.
Not to include wearable items or services like brake pads or fluid changes, the target information here is any component failures that require(d) repair.
Please copy and paste everything between the dashed lines below and edit/post with your information:
Model Year: 2015
Model: C300 4MATIC Sedan
Purchased New or Used: Used
Purchase Date MM/YYYY: 10/2018
Purchase Mileage (estimated): 27,000
Current Mileage (estimated): 46,000
Failures to date:
- Auxiliary Battery malfunction, replaced "Auxiliary Battery" PCB under factory warranty
- Windshield washer pump, replaced under factory warranty
- Leaking windshield washer fluid reservoir, replaced windshield washer pump O-ring under factory warranty
- Replaced broken power window glass lift switch button within main window control unit in drivers door (for Right Rear window)
- Replaced broken power window glass lift switch button within main window control unit in drivers door (for Right Front window)
- Sagging interior headliner on upper left and right of C-Pillar (yet to be repaired)
- Leaking windshield washer fluid reservoir (again 3 years after first repair, yet to be repaired)
Notes:
About a year and a half elapsed between the two window switch button failures. My windshield washer fluid reservoir just recently started leaking again, it leaks and drips out just behind the front left wheel fender liner as it did the last time.
I think I've been very fortunate (knock wood), not bad at all IMO.
I'm looking forward to seeing everyone else's total experiences... post up your junk!
This could be very helpful to a lot of other owners.Model Year: 2015
Model: C200 AMG Line German Built
Purchase Date MM/YYYY: 12/2018
Purchase Mileage (estimated): 78,000 kms
Current Mileage (estimated): 91,000 kms
Failures to date:
1- Auxiliary Battery Malfunction
2- Roof rack replaced. Stone was stuck on it damaged it.
3- Contaminated Fuel in Gas Tank. Replaced low and high pressure fuel pumps and cleaned reservoir.
Note: MB The Best or Nothing. Be Aware of Stealership.
Model Year: 2015
Failures to date:
We would look sharp cruising together.
I spent some time in Istanbul in June, so I was close to you, but I didn't have my car with me, lol.Last edited by Keith66; Aug 7, 2022 at 12:43 PM.
