C43 Transmission Fluid DIY 725 9G
Old Sep 9, 2022 | 11:15 PM
suran1991's Avatar
'17 C43
I took a crack at doing the transmission fluid myself today and thought i'd share it with everyone
Tool Required:
1/4 Ratchet
3/8 Ratchet
8mm or 5/16 for splash guard
10MM for transmission bracket to transmission mount
Female Torx E10 for transmission pan bolts
Female Torx E12 For transmission mount/bracket
Hex 8 for the transmission drain plug or special tool
Special Tool for Drain Plug
24MM open end wrench or adjustable wrench for Adapter - Mercedes-Benz (725589009000)
Flat Head Screwdriver to remove the level sensor and fill part.
Funnel
Oil Drain Pan
Parts:
Transmission Pan w/filter Mercedes-Benz (7252703707)
Transmission Pan
Transmission Fluid Mercedes-Benz Genuine ATF 236.17 (A000989280411BVLU)
Special Tools:
Socket Wrench - Mercedes-Benz (725589000900)
ATF Fill Adapter Compatible with Mercedes Benz 722.9/725 Thread: M12 x 1.5
https://www.amazon.ca/gp/product/B08Z7WYW6P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.ca/gp/product/B08Z7WYW6P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Fluid Pump
https://www.amazon.ca/gp/product/B098DVN5VR/ref=ppx_yo_dt_b_asin_image_o00_s01?ie=UTF8&psc=1 https://www.amazon.ca/gp/product/B098DVN5VR/ref=ppx_yo_dt_b_asin_image_o00_s01?ie=UTF8&psc=1
Step 1: Raise the car safety, use jack stands. Make sure the transmission is cool.
Step 2: Remove middle splash guard with 8mm or 5/16.
Step 3: Use the Hex 8 to remove the transmission pan plug. (There is a special tool for this as well and is included if you get the set on amazon or a tools site). The Hex 8 worked fine for me.
Drain Plug
Special Tool
Step 4: Use the special tool Socket Wrench - Mercedes-Benz (725589000900) to move from position 1 to 4. Position 1 is for highest volume in the pan and position 4 is used to drain.
Step 5: Remove the transmission mount/bracket to access all the transmission pan bolts. There are 8-Female Torx E12 to the chassis of the car and 4-10MM to the transmission mount. The transmission will lower so use a jack on the bracket to allow it to slowly drop.
Transmission Mount Bracket
Jack Supporting Transmission Mount Bracket
After Transmission Mount Bracket is removed
Step 6: Remove all the transmission pan bolts with a Female Torx E10 in a cross pattern.
Transmission Pan with Bolts
Step 7: Remove the pan, keep in mind that there is still almost a litre of fluid still in the pan so start from one end to allow the fluid to drain before you make a mess. Keep a note of how much fluid you drained in total.
Step 8: Remove the fill part and the level sensor from the old pan and install onto new filter. You can install new ones if you want. I reused the old ones. You can use a flat head to remove them.
Fill Part and Level Sensor
Step 9: Wipe down all areas with a clean cloth.
Step 10: Reinstall the transmission pan with a Female Torx E10 in a cross pattern, torque to 4ft/lbs and then a 90-degree turn.
Step 11: Make sure on the new pan the fill part is on position 1 for fill with the Socket Wrench - Mercedes-Benz (725589000900).
Step 12: Reinstall the transmission mount and bracket use a jack to raise it into place.
Step 13: Use the Adapter - Mercedes-Benz (725589009000), ATF Fill Adapter and a Fluid Pump to refill the same amount of fluid that you drained plus at least another additional 500ml. The pump I used from amazon was a lot of work, but it did the job, and I filled an extra 1L just to be sure. I refilled about 6 litres.
Fluid Pump
Step 14: Start your car in the AMG Menu and make sure the transmission temp is between 35 and 40 degrees.
Step 15: Remove the Adapter - Mercedes-Benz (725589009000) and use Socket Wrench - Mercedes-Benz (725589000900) to move to position 3 to check fluid level. Wait until most fluid is out and move the tool back to position 1.
Step 16: Install new plug supplied with new filter.
Step 17: Reinstall splash shield
Done
Old Sep 12, 2022 | 03:09 PM
Cosworth2000's Avatar
2022 E53 AMG
Great job.. Thanks for posting
Old Sep 13, 2022 | 06:21 AM
chassis's Avatar
2017 GLE350 4MATIC
Tool Required:
1/4 Ratchet
3/8 Ratchet
Funnel
Oil Drain Pan
Parts:
Transmission Pan
Special Tools:
(https://www.amazon.ca/gp/product/B08...?ie=UTF8&psc=1)
Fluid Pump
(https://www.amazon.ca/gp/product/B09...?ie=UTF8&psc=1)
Drain Plug
Special Tool
Fluid Pump
Done
Nice writeup. Doesn’t WIS call for changing gears with engine running at a specified trans oil temp?
Old Sep 13, 2022 | 09:17 PM
Mbjim's Avatar
Glc 300
Wondering at what mileage you serviced the transmission and the condition of the fluid!
Old Mar 26, 2023 | 07:30 PM
MaverickC43's Avatar
Amg C43
Sorry to be off subject
but I’m sure you guys have seen this
do we have drain hoses on both back bumpers
I assume maybe for water that runs down the trunk?
