I've been having some long start and initial rough idle issues for a couple of months now, so I decided to pull the driver side spark plugs and see if anything was immediately noticeable.
The middle cylinder on the driver's side is just BLACK.
Thoughts?
I'm running Shell 93 octane on map 2 of the JB4.
I have in the past run octane booster and map 3, but that was for less than 3 weeks total.
I have heard of injectors failing on several C43/C63s with higher mileage. Wonder if two of yours are leaking.
Also i assume you have the green fuel plug in on your JB4 and with the log have trims in a normal range?
