C180 coupe 2016 fuel gauge issue
c180 coupe 2016
Hey guys I need your help ,
i have c180 coupe 2016 (W205)
I filled my fuel to full tank, and when i drive it suddenly shows on my digital fuel gauge 4 bars , and than switches back again to full level.
were you think the problem at?
Where ever you have been fueling up your car, obviously has cheap gas. The problem with gas stations with cheap gas is that they do not take car of their fuel sump. You need to now replaced or remove the fuel pump and or either clean or replace fuel filter which is connected to the fuel pump. You may also need to check that the fuel leveler is not broken but even if it does not look like it is; replacing the fuel fuel pump and sender is better and less costly.
c180 coupe 2016
