Best lighting
Old Apr 3, 2023 | 03:46 PM
albeeC300's Avatar
C300
Best lighting
Hi all,
Wondering if any of you have tried and can recommend and HID lighting system for a base 16' C300. I have regular halogen low beams that are adequate as best. I've used XenonDepot before on my lexus and they were amazing, however those were Projector lenses which as I understand are better for properly focusing the beam. Not opposed to LED's but as I understand, they are not "there yet" compared to HIDs.
thanks!
Old Apr 6, 2023 | 03:56 PM
Cosworth2000's Avatar
2022 E53 AMG
There are companies out there that can help you with this.
Old Apr 8, 2023 | 04:03 PM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Originally Posted by albeeC300
Hi all,
thanks!
Why not upgrade the whole assembly?
Amazon Amazon
otherwise check out TRS
https://www.theretrofitsource.com/
Old Apr 9, 2023 | 01:07 PM
albeeC300's Avatar
C300
Interesting Benzdude... Very interesting! However that's too much cheese to plunk down on headlights. I think I'll find some LED bulbs and try that route. Too many other hobbies to spend money on! LOL
Old Apr 10, 2023 | 10:42 AM
satzzz_08's Avatar
Mercedes 2016 C300
You can try LASFIT. I am using it now and it is good. You can buy from their website or from amazon.
https://www.lasfit.com/pages/product...sule-headlamps
Old Apr 11, 2023 | 02:40 PM
albeeC300's Avatar
C300
So these are direct replacement, just plug and play or do they need a special bracket or something? 99 bucks .. not bad.
Old Apr 11, 2023 | 02:46 PM
satzzz_08's Avatar
Mercedes 2016 C300
Its plug and play. It needs a clip which comes with the LED bulb. You can see the instruction in their website and youtube
Old Apr 14, 2023 | 08:28 PM
albeeC300's Avatar
C300
Do you know of any instructions as to how to remove the current bulb there doesn't seem to bee to much space to work down there.. did you loosen the light cluster and pull it out towards the front of the car to swap the bulb? does that allen bolt (as well as the smaller lower allen holding the wire) have to come out?
Old Apr 14, 2023 | 08:32 PM
albeeC300's Avatar
C300
My bad.. you have to turn the tire in and remove a panel... Here's the video I found on youtube
Old Apr 18, 2023 | 01:46 PM
Jramz99's Avatar
2018 c300 sedan, RWD base package
I purchased LEDs from USR to replace my halogens. Easy install. Been running them for over a year. I love them! No regrets for me.
​​​​​​ https://www.uniquestyleracingstore.c...es/mbz-c-class
Old Apr 20, 2023 | 02:20 PM
albeeC300's Avatar
C300
Thanks again for the recommendation!! They look great and work amazing!!!
